Renecking an old classical
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=23712
Author:  HippieDave [ Sun Sep 06, 2009 12:48 am ]
Post subject:  Renecking an old classical
Hi, I'm new here and mainly have been lurking around since I've finally started building my first acoustic steel string. However, I am also thinking of renecking my old (1960's) Spanish made classical guitar, which appears badly in need of the operation. I tried a search here, but wasn't able to find any threads discussing that subject. Can anyone point me to some helpful resources?
Author:  Mike OMelia [ Sun Sep 06, 2009 1:25 am ]
Post subject:  Re: Renecking an old classical
Sounds like a big job! I assume you are talking about a new neck, new finger board, etc. Hanalai Moon makes very affordable necks. Send the old neck to them and they will create a new one.
Getting the neck off is another matter altogether, and then refinishing will be a project unto itself. How much is this guitar worth? Is it a collector's item? I think you should answer this question and then post some current pics.
Author:  WaddyThomson [ Sun Sep 06, 2009 9:09 am ]
Re-necking a classical will require removing the back if it is actually a Spanish build guitar. Without seeing pictures, it's hard to assess the project, but one option might be to remove the fingerboard, using a hot iron and pallet knives, then saw the neck off of the sides, make a new neck and bolt it on. I would, though, first ask why it needs a new neck. Is it warped? There might be other fixes that are less extreme.
