It is currently Mon Aug 11, 2025 4:43 pm
 Post subject: Shaping the Head
PostPosted: Sun Aug 30, 2009 4:30 pm
How many of you shape their heads by sticking a template to the blank with two sided tape and following it around on a table mounted router? I thought I'd give that a try and I have to say I found the tests a little scary. Perhaps it was because my test wood was pine but I found that the router ripped out big pieces when I was doing end grain or when I got close to the flared area near near the bottom. It could also be my lack of experience with a router. Anyway, unless I can feel safer, I'll stick to my drill press drum sander or try Robbie's filed filed drill bit-as-a-router method. Any advice?
 Post subject: Re: Shaping the Head
PostPosted: Sun Aug 30, 2009 4:40 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
I don't know of a safe way to use a router for the headstock. You could probably shape most of it with a router, but cutting the end or any place there's end grain is going to cause problems. I cut mind close with a band saw, the use a robo sander in my drill press.
PostPosted: Sun Aug 30, 2009 4:58 pm
Pat,
The most important part of routing is routing downhill. I would cut as close as possible to the line then route like the drawing. A sharp bit always helps too.
PostPosted: Sun Aug 30, 2009 4:59 pm
First name: Steven
Last Name: Metz
City: Nahunta
State: GA
Zip/Postal Code: 31553
Band saw and robo sander for me as well. You could do it with a pin router. I am a big fan of the robo sander. Most of use are not production shops so we do not need the production capacity of a pin router.
PostPosted: Sun Aug 30, 2009 5:12 pm
Close with the band saw, Robo Sander, then finish off with the router.
PostPosted: Sun Aug 30, 2009 5:18 pm
I do mine on the router table all the time ... the secret ???? I use a template that is bolted thru two tuner holes, and then using a template guide in the table top (3/8), route away slowly taking only 1/16 at a time in height. The bit I use is actually a 4 flute 1/4 inch bull nose end mill. All cuts are climb cuts, except the 'downhill' side of the top end of the headplate.
I tried using this template with a full height bearing bit once .. blew out wood left and right.
PostPosted: Sun Aug 30, 2009 6:36 pm
Like Tony says- bolt thru tuner holes. I use a spiral flush trim bit and a firm hand.
-C
Freeborn Guitars
and home of BeauGuard©
PostPosted: Sun Aug 30, 2009 7:23 pm
Thanks for the response guys. I didn't know what either a robo sander or a pin router were. I think I'll be ordering a robo sander.
PostPosted: Sun Aug 30, 2009 8:24 pm
So far, I don't use templates for this (except to trace the shape onto the wood). Band saw and then sand to the line on the belt, disc, and spindle sanders. Goes pretty fast. No set-up, no significant danger of messing it up.
Todd Rose
Ithaca, NY
PostPosted: Sun Aug 30, 2009 8:25 pm
Last Name: Shaw
City: Philadelphia
I use a bandsaw most of the time. If straight angles like a martin you can use a table saw. I use a spindle sander or my robo sanders to clean up the bandsaw cuts. Nothing worse then a a near finished neck and tearout caused by a router. I have found that spiral carbide bits are best for preventing tearout. I have a bit like this for template routing fender style electric necks. I buy them at MLCS.
http://www.mlcswoodworking.com/
PostPosted: Sun Aug 30, 2009 8:37 pm
I shape using a router, as pointed out By Tony & Chas, I cut close with a bandsaw so that there's minimal work for the router to do (essentially just cleaning up, maybe between 1/32 & a 1/16th) then screw a template to the headstock, picking up on positions later taken out by tuners or slots. Follow the cutting pattern Edward raised and it should be fast and clean with nice square edges [:Y:]
Headstock cleaned up and you can see the two screw holes
Which later disappear when the slots (or tuner shafts) are machined.
The pockets you can see around the tuner slots are routed using a bullnose bit and template that is double sided taped to the headstock. I'm only taking small depth cuts so the tape does this part of the operation just fine.I wouldn't rely on it for 'hogging' out big cuts.
Nick Oliver
http://www.oliver-guitars.com
PostPosted: Mon Aug 31, 2009 7:45 am
So for you guys using a router table for this, are you using an UpCut or Downcut Spiral Flush Trim Router Bits? Thanks, Peter
PostPosted: Mon Aug 31, 2009 8:55 am
I’m with Todd Rose. I end up sanding the edge after using the router anyhow so now I just skip that step.
Rich S
"The inconvenience of poor quality will linger long after the thrill of a bargain has been forgotten"
PostPosted: Mon Aug 31, 2009 9:02 am
Upcut will pull the wood into the table "Good"
Downcut will push the wood away from the table "Bad"
Rich S
PostPosted: Mon Aug 31, 2009 9:43 am
Mine is an upcut .... but in taking small bites in height, i doubt it matters. Its not a flush trim .. I use a template guide in the table insert.
PostPosted: Mon Aug 31, 2009 11:59 am
First name: Kenneth
Last Name: Casper
City: Northville
Country: U.S.A
I use a template attached with double sided tape. I hold the neck in a vise and use my laminate trimmer with a straight pattern cutting bit. Though I have a big router mounted in a router table, I like the higher RPMs of the laminate trimmer for this. I use a bandsaw to cut within a 1/16" of the pattern, then follow up with the laminate trimmer. As others have mentioned, the cut has to be shallow and do climb cuts to avoid tearout.
Pat, you might have better success with a laminate trimmer.
Ken
http://www.casperguitar.com
Users browsing this forum: bobgramann, Ken Lewis, TripodBob and 46 guests
