True Channel Jig http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=23567 |
Author: | segovia [ Tue Aug 25, 2009 8:20 am ] |
Post subject: | True Channel Jig |
Hi - I am placing my first order with Stewart Mac and I am debating getting the True Channel Jig for routing edge binding. As a first time builder would you say this is the easiest method for me to use ? John |
Author: | GordoninNM [ Tue Aug 25, 2009 8:30 am ] |
Post subject: | Re: True Channel Jig |
I'm VERY happy with mine. It is a well designed system that makes it pretty hard to screw up. The column mounted router makes all the difference, no rocking, no off square cuts. ![]() Gordo |
Author: | Fred Tellier [ Tue Aug 25, 2009 9:03 am ] |
I have used mine for 3 guitars so far and have no issues with it. Fred |
Author: | Lars Stahl [ Tue Aug 25, 2009 12:50 pm ] |
Just a pointer, do also check with John Hall at BluesCreekGuitars, he also sell a similar version of the stewmac´s . If you want good advice , try calling him , he will get you on the right track right away. ![]() Lars |
Author: | Jim_H [ Tue Aug 25, 2009 1:15 pm ] |
I have the stew mac jig and have had great success with it. My only complaint isn't really with the jig, but the stewmac bearing set is a little on the light side in terms of selection. I found myself halfway in between sizes using their bearings too often. I ended up ponying up for the full set (two sets actually) of the LMI bearing sets. |
Author: | bluescreek [ Tue Aug 25, 2009 2:02 pm ] |
With this jig you need to be aware that laminate trimmers do not all have the same mounting angle . This can make the channel off square . |
Author: | segovia [ Tue Aug 25, 2009 2:53 pm ] |
I asked a question in am earlier post, its seems Bosch and Makita are compatible and I can get them in the UK Thanks John |
Author: | GordoninNM [ Tue Aug 25, 2009 3:04 pm ] |
Re Bosch trimmer, I had to make a 1/4" Lexan adaptor plate to get my Bosch Colt trimmer to work. Took about 1/2 hour to make. Lexan plate with countersunk screws attaches to trimmer base casting, and with screwheads countersunk in the opposite direction it attaches to the levitating aluminum base on the vertical router column. Some other trimmers look like they would be a straight ahead bolt-up, but my Bosch baseplate screw holes did not line up with the pre-drilled holes in the jig, hence the adaptor plate. Gordo |
Author: | segovia [ Tue Aug 25, 2009 3:19 pm ] |
Stewart Mac use the Makita in the demo, since I don't think there is much in the laminate trimmers I may go for a Makita. I'll post a question on their website and feedback what they say. Thanks John |
Author: | Mark A Thorpe [ Tue Aug 25, 2009 3:22 pm ] |
I love mine. I use mine with a Freud FT750 Laminate Trimmer bolted right up. |
