Woods that tend to bleed?
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=23341
Author:  sdsollod [ Thu Aug 06, 2009 6:19 pm ]
Post subject:  Woods that tend to bleed?
On my second build (I've done 4 so far and starting #5) I used cocobolo for the rosette. When I put on the Z-poxy it bled. gaah I managed to overcome that (to some degree). So, I know cocobolo bleeds. I've used rosewood and lacewood (which turned out very nice) and I got no bleeding. I'm getting ready to use claro walnut and I expect it not to bleed. What about african blackwood? ... ebony? ...any others tend to bleed?
Author:  Glenn LaSalle [ Thu Aug 06, 2009 6:42 pm ]
Post subject:  Re: Woods that tend to bleed?
I am certainly no expert, but I bent Madagascar RW bindings and they "bled"- left some residue on my steel bending slats.
Glenn
Author:  truckjohn [ Thu Aug 06, 2009 8:22 pm ]
I would expect it out of every single flavor of Rosewood on the planet...
I might be careful with about any of the oily tropical woods...
Then you got the regular problem with anything Dark -- dust staining stuff... Ebony is famous for its black dust getting on *EVERYTHING*
Good luck
Author:  Joe Beaver [ Fri Aug 07, 2009 3:02 am ]
The best bet is test a piece of the wood with whatever finish you are using. If it is going to bleed into a lighter wood then carefully coat the bleeding wood with the epoxy. Masking tape may help on things like maple bindings or the sound board. Then remove the tape, let the epoxy dry, sand lightly and reapply the epoxy over the whole piece, bindings and all. You have it sealed so there should be no problem. (epoxing the top is optional. I only do it with cedar and flamed redwood.)
Also be careful wiping the wood with naptha or alcohol. That will cause bleeding. (don't use naptha if you are planning a water based finish, unless you use it before you seal with epoxy. I would still just use alcohol)
Joe
Author:  Erik Hauri [ Fri Aug 07, 2009 6:58 am ]
Bloodwood
duh
seriously
Author:  RaymundH [ Fri Aug 07, 2009 7:03 am ]
PADAUK... Bleeds like crazy and the dust gets everywhere...
Author:  Bob Garrish [ Fri Aug 07, 2009 10:10 am ]
Walnut and ebony don't bleed, but ebony dust does get everywhere. Generally, it's easiest to just scrape lightly with a razor after you're done messing with the ebony to take the dust off of lighter woods. It doesn't penetrate very deep at all.
Author:  Mike Collins [ Fri Aug 07, 2009 12:47 pm ]
For bleeding woods I spray a light coat of blond shellac on them.
I spray it on because wiping would cause bleeding.
You can use spray can shellac but beware !
it's mostly thinner and to thick a coat will draw the oils out of the oily woods and bleed onto tops & such .
After it's dry you can apply any finish over it without bleeding.
Author:  Michael Dale Payne [ Fri Aug 07, 2009 12:58 pm ]
I agree
Shellac sealing keeps the oils from inpregnating lighter woods. still will require some scraping back aft the fill is complete
Author:  David Newton [ Fri Aug 07, 2009 1:52 pm ]
I don't know which woods bleed, but I know which parts, my FINGERS!
Author:  MRS [ Fri Aug 07, 2009 2:38 pm ]
Padauk can bleed. Washcoat of dewaxed shellac can prevent this.
Author:  Corky Long [ Mon Aug 10, 2009 9:47 am ]
Black Walnut is an interesting one. While I haven't had trouble with bleeding per se, it will stain your hands (and other things too, I'm thinking) something fierce if you get the sawdust on them.
