It is currently Wed Jul 09, 2025 1:36 pm
PostPosted: Mon Jul 27, 2009 9:12 pm
Last Name: Livermore
State: Minnesota
I'm about to heat some glue and put braces on an instrument based on the '37 Hauser plans.
Something inside just doesn't feel right about bracing any guitar using 3mmX3mm toothpicks for the fanbraces.
I've mostly built steel strings, but it just doesn't feel quite right.
Has anyone else encountered this before?
dave
PostPosted: Mon Jul 27, 2009 9:34 pm
First name: David
Last Name: LaPlante
Classical guitars are an entirely different approach from steel strings and that is precisely why at this point I no longer build steel strings.
The fan braces being 3 mm (or 3.5 mm?) is rather small even for a classical but you have to remember that Hauser's approach was to use a thicker top (2.5-3.00 mm) rather than other makers whose tops might go down all the way to 1.6-1.8mm at their thinnest and whose fans might be on the order of 6mm wide.
If all of this seems mighty flimsy to your steel string oriented sensibilities that's normal.
You should however set those sensibilities aside and stick to the stated Hauser specs.
If you are using the GAL plan by Richard Brune you should get good results.
My copy of the '37 Hauser from the Brune plan:
PostPosted: Mon Jul 27, 2009 9:36 pm
Someone posted an old (the famous spanish guy) guitar a while back, built like a baroque guitar, with NO braces, just around the soundhole. It was a student model, but no bottom bracing.My baroque has no bottom braces, but is only 10" wide.
PostPosted: Mon Jul 27, 2009 9:45 pm
State: Minnesota
Thanks for the reasurance.
I'll cross my fingers and do my best.
PostPosted: Tue Jul 28, 2009 12:13 am
First name: David
Last Name: Schramm
Another element that might not be on the Brune plan is that Hauser's lower transverse bars dip inwards about 0.002-0.003". Don't make it flat or arched.
