suggestions please - cut a brace notch too deep
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=23182
Author:  ayavner [ Thu Jul 23, 2009 10:44 pm ]
Post subject:  suggestions please - cut a brace notch too deep
Hi all - hoping to see what the collective wisdom has to offer on this one...
I was cutting the notches in the rim for the back braces. One of them went a bit deep, to the extent it doesn't even look like the binding will cover it completely. Should i epoxy in a small piece of the side wood and scrape flush? Dangit, it was going so well :(
Open to suggestions, thanks!!!
Adam
Author:  the Padma [ Thu Jul 23, 2009 11:28 pm ]
Post subject:  Re: suggestions please - cut a brace notch too deep
Use wider binding.
the
Padma
Author:  Joe Beaver [ Fri Jul 24, 2009 1:07 am ]
Yep!!!! I've done that one myself. I just made a little piece from the side material that I could use to fill the hole. I matched the grain as best I could. Then I glued it in with LMI white (it drys clear). You couldn't see it once I scraped it smooth and put the binding on.
Then again if it is close you can put in wider binding with a purling line like Padma suggested. Something like this:
Now I just inlet the braces through the lining, stoping at the sides.
Good Luck.
Author:  Howard Klepper [ Fri Jul 24, 2009 1:28 am ]
Don't use wider binding. Fill in with side wood.
Author:  Joe Beaver [ Fri Jul 24, 2009 1:30 am ]
Tried to post this picture as an example. Maybe it will work this time...
Author:  ayavner [ Fri Jul 24, 2009 7:12 am ]
OK, so the consensus seems to lean towards filling in with a piece of side wood. Should I do this after I have the top glued on and edges flush, but before routing for the binding? Or after the binding is installed so I know exactly how big a piece to put in?
And, just use white glue, not epoxy?
thanks all for the rescue!! I felt like an idiot...
Author:  Bruce Dickey [ Fri Jul 24, 2009 8:53 am ]
I use a little dremel with the depth set at about .060 and thin my brace ends accordingly. You really have to control the inlet to a close tolerance to avoid the problem entirely. Good luck patching it. I've never done the linings only thing, it's just really easy to rout a slot with the dremel and no worries of going too deep that the binding doesn't cover. The brace ends get routed back flush when routing for the binding itself.
Author:  Joe Beaver [ Fri Jul 24, 2009 1:02 pm ]
I suppose epoxy would work ok but it has its draw backs. One is that it takes a long time to dry so you'll have to clamp the piece in (tape?). The other is that you may have more of a glue line with it, maybe not, depending on the color of the sides.
I like LMI white because you can hold the piece in by hand for about 30 seconds and it will grab it pretty well. If you do it with clean hands and hold it pretty tight it makes for a fairly unnoticeable glue line. HHG is probably the best but I've never taken the plunge.
