New Luthier Tips du Jour video - bolt on mortise and tenon http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=22906 |
Author: | Robbie O'Brien [ Mon Jun 29, 2009 9:13 am ] |
Post subject: | New Luthier Tips du Jour video - bolt on mortise and tenon |
The newest Luthier Tips du Jour instructional video is on Youtube. The topic is the bolt on mortise and tenon neck joint. Subtitles are available in both English and Portuguese and you can translate them into any other language by using the CC option on Youtube. As always, comments and discussion are welcome. Enjoy! |
Author: | Jim_H [ Mon Jun 29, 2009 9:48 am ] |
Post subject: | Re: New Luthier Tips du Jour video - bolt on mortise and tenon |
Nice work Robbie! Thanks so much for doing this... Is the next video going to be how to build a set of M/T jigs? ![]() ![]() |
Author: | JJ Donohue [ Mon Jun 29, 2009 9:59 am ] |
Nice video, as always, Robbie! Your presentations get more professional with each new chapter! Thanks for posting. The neck tenon routing jig that you highlight (AKA Woolson Neck Tenon Jig) has a great construction drawing that used to be available for purchase here at the OLF. Check with Lance or Michael Payne for more details. It's a great jig and well worth building if you build your own necks and plan to build more than one guitar. |
Author: | Bill Hodge [ Mon Jun 29, 2009 10:06 am ] |
Mr. O'Brien does it again. Great work Robbie thanks! ![]() |
Author: | Robbie O'Brien [ Mon Jun 29, 2009 10:09 am ] |
Thank you Jim and JJ. I have been using a version of this jig for years and within the last few years added the metal rod part of the jig after seeing the Woolson Jig. I always get emails from people asking about plans and didn't know any plans existed anywhere. If someone knows about a set of plans please let me know so I can pass this info on. |
Author: | Fred Tellier [ Mon Jun 29, 2009 12:03 pm ] |
Another great video Robbie, you make getting building info much easier. I wish I was beginning now instead of 4 years ago, I would have avoided a lot of extra web searching and mistake corrections. I also am interested in plans if they are still available. Fred |
Author: | ayavner [ Mon Jun 29, 2009 1:07 pm ] |
hehe: "tighten the jig until you hear a crack, then back off a quarter turn". Sheer gold, man... priceless. Thanks! adam |
Author: | Randolph [ Mon Jun 29, 2009 2:47 pm ] |
Robbie, Fabulous as always. They just keep getting better and better! This one, in particular with the jigs is a huge help on a fairly daunting area (neck angle). I assume the next video will be on body crack repair after backing off jig tension? ![]() |
Author: | Senf [ Tue Jun 30, 2009 8:16 am ] |
Robbie, your jig looks a lot better than the one on your dvd (you complained about the dust shooting back on your face) I got from LMI a few years ago. I use StewMac templates and built a similar fixture with their plans. Great video. BTW, I use brass thread inserts instead of barrel nuts. Does one have an advantage over another? Thanks |
Author: | Robbie O'Brien [ Tue Jun 30, 2009 9:34 am ] |
Senf wrote: Robbie, your jig looks a lot better than the one on your dvd (you complained about the dust shooting back on your face) I got from LMI a few years ago. I use StewMac templates and built a similar fixture with their plans. Great video. BTW, I use brass thread inserts instead of barrel nuts. Does one have an advantage over another? Thanks The design is the same as the jig used in my dvd. This is just another jig that was actually put together as a prototype of my jig by Tracy Leveque from Luthier Suppliers. Perhaps he could be talked into putting it into production. When you say you are using threaded inserts I assume you are screwing them into the end grain rather than through the grain like the barrel nuts. Both methods will work but I prefer the cross grain inserts. |
Author: | JRessler [ Tue Jun 30, 2009 12:56 pm ] |
Robbie Excellent info on all of these! Thanks One question - So how do you deal with the gap under the fingerboard extension above the soundhole, or is that a separate video?? |
Author: | ayavner [ Tue Jun 30, 2009 1:38 pm ] |
JRessler wrote: Robbie Excellent info on all of these! Thanks One question - So how do you deal with the gap under the fingerboard extension above the soundhole, or is that a separate video?? Clamp it till you hear a crack, then back off... ![]() ![]() |
Author: | Robbie O'Brien [ Tue Jun 30, 2009 7:45 pm ] |
JRessler wrote: Robbie Excellent info on all of these! Thanks One question - So how do you deal with the gap under the fingerboard extension above the soundhole, or is that a separate video?? Thanks John. If I understand your question, the gap is due to the neck angle. I adjust the shelf of my jig to find the correct neck angle and then cut the tenon. |
Author: | ayavner [ Tue Jun 30, 2009 8:21 pm ] |
Hey guys, don't forget.... we all wanna see more and more of these, so take a sec and make a donation if you are able! It's over at obrienguitars.com home page. |
Author: | sprouseod [ Thu Jul 02, 2009 8:33 am ] |
Hi Robbie, just curious how does the plate the holds the rod and the rough neck pivot? Thanks Richard |
Author: | Robbie O'Brien [ Thu Jul 02, 2009 9:27 am ] |
sprouseod wrote: Hi Robbie, just curious how does the plate the holds the rod and the rough neck pivot? Thanks Richard It is attached to the upper deck by a couple of hinges. |
Author: | sprouseod [ Thu Jul 02, 2009 10:05 am ] |
Thanks Robbie |
Author: | Aaron O [ Fri Jul 03, 2009 4:10 am ] |
I've been working through a M&T bolt-on in my mind for a while (as in over the past 5 or 6 builds). This is probably the closest I've been without actually drawing out a plan to start cutting the jig. Thank you. Aaron |
Author: | Chris Paulick [ Mon Jul 06, 2009 10:29 am ] |
Nice video Robbie and helpful. You now need a hole template fixture. ![]() |
Author: | Chris Paulick [ Tue Jul 07, 2009 11:38 am ] |
ayavner wrote: Hey guys, don't forget.... we all wanna see more and more of these, so take a sec and make a donation if you are able! It's over at obrienguitars.com home page. I don't think this is the place for that. You aren't sending donation to everyone else who shares their knowledge on this and other forums. Edit If you remove the following post then remove this one too. |
Author: | ayavner [ Tue Jul 07, 2009 11:44 am ] |
Ahhh.. you're probably right, if the mods agree, please remove. Didn't mean to offend. adam |
