It is currently Mon Aug 11, 2025 2:42 am
PostPosted: Wed Jun 24, 2009 8:32 pm
I finally decided to make another fox style bender so I have 1 always setup to do venetian cutaways. ....
Can I see some cauls and presses? I know there is to be some real clever ideas out there....and if there's is a better way, I'm game! Eat Drink
PostPosted: Wed Jun 24, 2009 8:38 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
I need to do that. For cutaways I bend the back half and the waist in my bender and do the cutaway on a hot pipe.
PostPosted: Wed Jun 24, 2009 8:42 pm
I have a press that attaches to the bender but that ties up the bender for a while. If I build 2 I can do both sides at once! bliss
PostPosted: Thu Jun 25, 2009 12:24 am
I just made one and bent my first Venetian cutaway. I used a rolling pin for a caul and made the radius of the cutaway to match. The ribbon holds down the lower spring steel slat so it won't spring up when taking the side out. I creased a couple of mahogany practice sides before getting the hang of applying the pressure. Thanks to John Hall's web site I learned that you have to hold up the end of the sandwich to keep tension on the lower slat while tightening the caul.
PostPosted: Thu Jun 25, 2009 9:56 am
press ??? ..try this one ... solid mold and plug, some gloves .... I couldnt believe it until I saw it. He is bending english walnut, at about 80 thou ....
http://luthiertube.com/video/453/side-bending
PostPosted: Thu Jun 25, 2009 11:12 am
Check out the building narrative here. FWIW, the build is at Huss and Dalton.
The cutaway bending form is very near the end of a VERY long, single html page full of pic...so it might take a while to load.
It's a single stand alone "second stage" bender caul used with a heating blanket. I've used it 3 times in the last year and have had great success. I like it because I can focus on the waist bend first. THEN I can focus on the cutaway bend by itself, rather than performing both bends at the same time. It's also very simple to make and doesn't take up as much room as a second bender, more steel slats, etc.
Joe
PostPosted: Thu Jun 25, 2009 1:04 pm
I can see how well it works specially in the cutaway area... simplicity works wonders.
PostPosted: Thu Jun 25, 2009 2:22 pm
Very cool Tony. Rick Turner would like that guy. He's got a cut to the chase personality.
TJK
Users browsing this forum: meddlingfool and 41 guests
