Got CA Solvent?
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=22837
Author:  SteveSmith [ Tue Jun 23, 2009 9:12 am ]
Post subject:  Got CA Solvent?
So about three years ago I bought a bottle of CA solvent and stuck it on the shelf. Never used it, never needed it then...................
Last night I glued two fingers together, really did a good job too idunno
That solvent came in real handy. :oops:
If you don't have any you might want to get some. I guess acetone would do good too.
Author:  Antonio [ Tue Jun 23, 2009 10:29 am ]
Post subject:  Re: Got CA Solvent?
Steve,
Thank you for the info. Do you know any solvent for contact glue (adhesive).
I would like to clean my sanding board to glue another sheet of sanding paper and it is taking tooo long [headinwall]
Author:  SteveSmith [ Tue Jun 23, 2009 11:31 am ]
Antonio wrote:
Steve,
Have you tried naptha? That usually works for sticky-backed sandpaper, otherwise maybe someone else has an idea.
Author:  Lillian F-W [ Tue Jun 23, 2009 11:41 am ]
They use lighter fluid at the bookshop to remove old price stickers and residue from used books.
Author:  SteveSmith [ Tue Jun 23, 2009 12:20 pm ]
Good point, lighter fluid and Naptha are the same thing.
Author:  woody b [ Tue Jun 23, 2009 12:37 pm ]
Some lighter fluids are no longer naptha based. Naptha is sometimes spelled Naphtha. It's the same thing. You can buy a big bottle of naptha(or naphtha) at a hardware store for the price of a small bottle of lighter fluid. Obviously it's extrememly flammable so be careful.
I was told the CA "debonder" is a mixture of acetone and cooking oil. I just keep some acetone handy. I have a tendency to glue.........everything to...........everything.
FWIW, I don't think Naptha will work on CA, but it works great for most adhesives.
Author:  SteveSmith [ Tue Jun 23, 2009 1:52 pm ]
I didn't know that, I have a can of lighter fluid at work I've had for probably 10 years.
Author:  npalen [ Tue Jun 23, 2009 2:48 pm ]
Confucius say: He who spills CA on floor best not work barefoot.
Author:  Mike OMelia [ Tue Jun 23, 2009 3:45 pm ]
I thought fingernail polish and acetone (same thing?) were good solvents for CA. BTW, gluing your fingers together is a neat trick right before the big games on Saturday which normally coincide with the Honey-Do list being handed over. You can still hold a long neck bottle too. 8-)
Author:  John Shannon [ Tue Jun 23, 2009 3:56 pm ]
Have you tried "Goo gone" ? Pretty easy to find and it's worked well for me in removing some pretty tenacious adhesives.
Author:  SteveSmith [ Tue Jun 23, 2009 4:22 pm ]
I may have to try that one.
Author:  Rob Warren [ Tue Jun 23, 2009 4:59 pm ]
Fingernail polish remover WITH acetone in it. They make some acetone free brands, and it won't work on CA. It's the acetone that dissolves the glue. Don't ask how I found that little tid-bit out....
Author:  Bob Garrish [ Wed Jun 24, 2009 12:58 am ]
She.
Author:  John Copley [ Wed Jun 24, 2009 10:10 am ]
If you glue two fingers together with CA glue take a Bic pen or similar(octagonal shaped body) and roll it through the two fingers from the inside to the out. Bingo , no pain, nothing, instant release. Try it and see. It also makes a good party trick.
Cheers Chopper
Author:  SteveSmith [ Wed Jun 24, 2009 10:27 am ]
Cheers Chopper
That would work good for two finger tips. Not so good for side to side which is what I did. :)
