14th Hump/Dive http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=22790 |
Author: | John Hale [ Wed Jun 17, 2009 7:19 pm ] |
Post subject: | 14th Hump/Dive |
Guys I'm close to finishing my second instrument now, 1 guitar, 1 Uke, and I've used bolt-on necks, after fretting on both the tongue on bolting to the body there is always this fall away I assume its created when the frets are hammered in and the upper end of the fingerboard expands. What are the ways to avoid this and get a good fret job? |
Author: | Dave_E [ Wed Jun 17, 2009 8:58 pm ] |
Post subject: | Re: 14th Hump/Dive |
Hi John, Exact same thing happened to me. What I suspected (as I was doing it ![]() Frets do NOT need to be installed so flippin tight! They got tangs and some Elmers (some even use epoxy). They are not going anywhere! Give it a try. Dave |
Author: | Lillian F-W [ Wed Jun 17, 2009 9:05 pm ] |
If you are installing the frets off the next, then you can help set them by supporting the fretboard at the ends and use a clamp in the middle to pull it down into a gentle U. This forces most of the fret barbs into the wood. It's not a perfect solution, but it goes a long way to avoiding the bowing caused by having too narrow kerfs. |
