Low fret dilemma
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=22582
Author:  Paull [ Mon Jun 01, 2009 9:38 am ]
Post subject:  Low fret dilemma
For about a month I noticed some bad string buzz and/or choking of notes when playing on one certain fret.
It's a Stratocaster.
Strings high E to the 4th would buzz at the 7th fret, no where else.
I discovered the 7th fret was lower than the others.
So I files down the frets to even them out and recrowned the tops.
This cured 3 strings, it still buzzes for the 4th string at the 7th fret.
The 4th string has improved but not 100%.
My question is, should I go back and shave some more off all the frets or just look for something uneven around the 4th string area?
Thanks.
Author:  Jody [ Tue Jun 02, 2009 6:43 am ]
Post subject:  Re: Low fret dilemma
you can just treat the problem areas by sanding them down slightly .. Jody
Author:  Paull [ Tue Jun 02, 2009 8:23 am ]
Thanks, I'll try that.
Author:  JasonM [ Tue Jun 02, 2009 10:26 am ]
If you have a single high fret, you can bring it down level with the rest, but a low fret is a different issue. You'd need to bring all the other frets down to its level, or you'll just chase the buzz around. Need a large fret levelling beam, to glide accross the entire fretboard (to do it right).http://www.stewmac.com/shop/Fretting_supplies/Leveling/1/Fret_Fingerboard_Levelers/Pictures.html#details
Author:  Paull [ Tue Jun 02, 2009 11:30 am ]
That's exactly what happened.
All frets were equal in height so they all had to come down.
After thinking about it some more I realized this and filed the rest down and everything is good.
Author:  James W B [ Thu Jun 04, 2009 4:20 pm ]
Just replace the low fret with a new one and file it down to the level of the rest.
James
