which grits? http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=22430 |
Author: | Jody [ Wed May 20, 2009 6:40 am ] |
Post subject: | which grits? |
What grits of sand paper do you run on your twin drum sander, for sanding top and back plates? thanks Jody |
Author: | jordan aceto [ Wed May 20, 2009 8:20 am ] |
Post subject: | Re: which grits? |
I have 80 and 120/150, although i usually have it set up to only use one drum at a time. I go for 60 grit if there is a lot of material to hog off. |
Author: | muthrs [ Wed May 20, 2009 9:02 am ] |
Same here. |
Author: | Alain Desforges [ Wed May 20, 2009 9:11 am ] |
I load mine with 100/120 or 120/150. I prefer the higher grits as I find the lower ones leave me with too much sanding afterwards. A drum sander is not a planer and shouldn't be used as such. If I have a lot of material to take off, I just take more passes. A good planer is on my 'goodies I want' list... Anyways, if you try to take off too much material at once, you'll clog up your paper, regardless of grit. |
Author: | Jody [ Wed May 20, 2009 4:31 pm ] |
cool , thanks Guys! jody |
