It is currently Mon Aug 11, 2025 6:08 pm
 Post subject: Cutaway Bending Aid
PostPosted: Tue May 12, 2009 5:38 pm
I finally got around to doing a venetian cutaway and it was pretty obvious that taking it out of the bender without putting tension on the cutaway was not going to be easy. I saw where Sylvan just holds the lower slat in with his hand but I was not too good at that. This is what I came up with and it worked great. A thin tough ribbon that won't stretch. Check your wife's sewing basket or rummage around in a fabric store for the right one. Figure out where the cutaway will fall on the side and put the ribbon in when you make your sandwich and anchor with spring clamps so it won't move.
After leaving the side in the bender 24hrs I tied the ribbon as tight as I could to rope cleats on the tower. I have a removable top on my bender so with the lower bout slat anchored too I could lift the side straight out with no tension.
Terry
 Post subject: Re: Cutaway Bending Aid
PostPosted: Tue May 12, 2009 5:42 pm
First name: Mark
Last Name: Thorpe
City: Valparaiso
State: Indiana
In the last picture that sure is a fancy adjustable mold you have there. Interesting.
PostPosted: Tue May 12, 2009 6:40 pm
Brilliant, Terence! You bone docs got all kinds of clever answers! :D Thanks!
Users browsing this forum: No registered users and 41 guests
