LMI fretwire: Is the curved piece cut to good useable radii?
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=22306
Author:  radsboy [ Thu May 07, 2009 7:06 pm ]
Post subject:  LMI fretwire: Is the curved piece cut to good useable radii?
I have 3 pieces of LMI fretwire which arrived in the box curved. Interestingly, when I lay them end to end on the floor they make a close to perfect circle of a little better than 10" radius. Is this a good curve to work from when I cut the pieces, or should I try to bend more (or less)?
-David
Author:  Josh H [ Thu May 07, 2009 7:12 pm ]
Post subject:  Re: LMI fretwire: Is the curved piece cut to good useable radii?
I use the LMI wire as I receive it and it works fine. My fretboards are a 16 radius. I press frets up to the 10th and hammer in the rest. You should be fine to use it as is.
Josh
Author:  Hesh [ Thu May 07, 2009 7:18 pm ]
Yeah I agree with our friend Josh and although I don't know what LMI's radius for their fret wire is I like to radius my fret wire to a slightly smaller radius than the radius of the board. When hammering I tap in the ends first which is why the tighter radius of the wire is helpful, at least to me.
Author:  radsboy [ Thu May 07, 2009 9:06 pm ]
Thanks -
Author:  John How [ Thu May 07, 2009 9:34 pm ]
I buy the 100ft rolls that LMI sells and use it just that way, It's about a 10 inch radius or so I'm guessing.
Author:  Barry Daniels [ Fri May 08, 2009 9:37 am ]
I ALWAYS hold the fretboard up to the fretwire to make sure the wire touches the board at the edges and there is about 1/16" gap at the middle. Anything much more or less that will get re-bent.
And, I check individual frets as I cut them because sometimes they need a little touching up on the radius. I may be a little too particular about this.
