It is currently Sun Aug 10, 2025 3:28 am
 Post subject: Body Taper
PostPosted: Wed Apr 29, 2009 1:14 pm
First name: Stephen
Last Name: Ziegenfuss
City: Jackson
Broad Question:
When determing body taper, are we generally looking for a certain percentage decrease from heel to neck block, or are we wanting to end up at a specific depth at the neck block?
I am working on a large body design, and am not quite sure what to do with the taper.
Thanks!
Stephen
www.ziegenfussguitars.com
 Post subject: Re: Body Taper
PostPosted: Wed Apr 29, 2009 2:19 pm
I'm sure there is some dynamic (read velocity of sound, body volume, tonal quality) reason for the taper but one of main reasons for the taper is player comfort.
When building bigger guitar bodies, I think the tapper is important and ensuring the comfort of the player is taken into consideration. I personally like 1/2" of body tapper on thin bodies ie: 4"+/- at the tail, and 3/4" on 'thicker' bodies ie" 4-1/2"-4-3/4" at the tail. I also don't really like a thick body on a big guitar, but I do like a thick body on a smaller guitar.
Personal preference I think will generally determine the body taper.
PostPosted: Wed Apr 29, 2009 2:29 pm
First name: Stephen
City: Jackson
Thanks Rod,
That was my assumption, but I wanted someone to independently "affirm" it. Obviously the body depth has mcuh to do with the air volume, and the total amount of air you could theoretically move. Taper, accordingly can have the same affect.
I did look at a good number of models, and it appears that the standard rule of thumb is +/- 20% decrease in body depth from heel to neck...
Thanks so much!!!
Stephen
PostPosted: Wed Apr 29, 2009 2:51 pm
I thought a lot about this also and for steel strings found much the same results as you did. I was really surprised to find that with classical guitars there was little to no taper on many models. I thought that was very interesting.
I have made a few with a lot of taper, like 4" to 2 7/8. I think of it as a trade off between clarity (more taper) and fullness (less taper) although of course it is not nearly that simple.
Burton
Brookline, MA.
PostPosted: Wed Apr 29, 2009 10:02 pm
First name: Chuck
Last Name: Hutchison
City: Houston
McPherson makes a reverse taper guitar. Larger towards the front and narrow on the end.
Wonder how that would feel playing?
PostPosted: Thu Apr 30, 2009 12:42 am
Is that for lefties ;)
PostPosted: Thu Apr 30, 2009 4:19 am
The taper is there to help in structural support on steel stringers. While it sure helps to feel more comfy
PostPosted: Thu Apr 30, 2009 5:48 am
First name: Mark
Last Name: Thorpe
City: Valparaiso
State: Indiana
The reason there is a taper on the back is because of beer bellies, if the back was flat your left arm would have to be about a foot longer laughing6-hehe just kidding.
