It is currently Wed Aug 06, 2025 11:05 am
PostPosted: Mon Mar 23, 2009 7:19 pm
Sounds like a stupid question, but I can't use strong solovents to clean the fine sanding dust for handling wood indoors, didn't want to use water damp rag.
Got lots of rubbing alchohol, is this safe to use on wood? Just a damp wipe to clear the dust from sanding.
PostPosted: Mon Mar 23, 2009 7:35 pm
Mabey a shop vac with a brush atachment would work.
PostPosted: Mon Mar 23, 2009 11:00 pm
First name: Darrin
Last Name: Oilar
City: Cottonwood
Zip/Postal Code: 96022
I can't see why it wouldn't be ok, but I think it's still about 30% water, so you'll probably be raising the grain with it.
Darrin
PostPosted: Tue Mar 24, 2009 3:17 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
You can use naptha or something. Don't use rubbing alcohol, they contain water which will raise the grain and also in my experience, even pure alcohol absorbs water causing thin wood pieces to warp (I tried that on a headplate that's what it did...)
Typhoon Guitars
PostPosted: Tue Mar 24, 2009 5:20 am
I keep a supply of 190 proof grain alcohol in the shop for shellac. I use it sometimes to wipe dust away before gluing, mostly on spruce. Don't use any kind of alcohol on rosewoods and other color-rich exotic woods. It will make the color run and smear.
Todd Rose
Ithaca, NY
PostPosted: Tue Mar 24, 2009 9:03 am
How about using a tack cloth after a vacuum?
PostPosted: Tue Mar 24, 2009 9:08 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
You could try aloohol...
Typhoon Guitars
PostPosted: Wed Mar 25, 2009 3:31 am
I've had problem with shellac finishes after using a tack cloth....some of them have silicon. If using a commercial tack cloth and you dont know whats in it I'd reccommend making up your own tack cloth. Ive also had problems with zinc stearate contained in some non clog sandpapers. Ive switched to garnet paper and use a vacumn followed by a wipe with a clean hand before starting finishing.
PostPosted: Wed Mar 25, 2009 3:35 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I never liked tack cloth. They said you need it for finishing but I tried it and they felt like a cheesecloth coated in this stick adhesive gunk that leaves stuff behind sometimes (BAD), so I used a clean damp cloth in the old days before they had microfiber cloth. Now I use microfiber cloth and it gets rid of dusts very well.
Typhoon Guitars
PostPosted: Wed Mar 25, 2009 8:32 am
Gersons is what I have. I didn't realize there was all that to know about them. I thought they were just cheese cloth with shellac on them. It's like they have been around forever like spit coating.
Users browsing this forum: ChuckB and 42 guests
