Back bracing heights question. http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=21538 |
Author: | Lars Stahl [ Thu Mar 19, 2009 10:17 am ] |
Post subject: | Back bracing heights question. |
I am bracing a back and I am using 1/4" width on all braces !! its an SJ, 16"+ lower bout, EIR. will this be ok or would you guys recommend wider braces on the 2 lower braces ? . They are allready glued on. but if it´s a must, then Ill shave em off. so what say you. Lars. |
Author: | Michael Dale Payne [ Thu Mar 19, 2009 10:24 am ] |
Post subject: | Re: Back bracing heights question. |
Obviously it is not the OLFSJ as the lower bout is 15 ½” not 16+. To address your question I would need to see the locations and the shape of the body but if you have two in the lower bout and the are roughly 5/8 tall I suspect you are fine |
Author: | Lars Stahl [ Thu Mar 19, 2009 11:04 am ] |
Its my own design, allthough I am using your bracing scheme ! So I am happy your replied first ![]() ![]() So if I use 5/8" tall on the lower 2 braces, then can I use same on the upper 2 or can I use lower on those like 3/8" ? I got a bit confused as reading the plan. X vs normal. Sincerely Lars. |
