has anyione else experienced this with rosewood?
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=21533
Author:  Jody [ Thu Mar 19, 2009 7:19 am ]
Post subject:  has anyione else experienced this with rosewood?
I had radius sanded my rosewood finger board monthes ago, I went ahead and recently installed the fret wires without rechecking the trueness of the board, I had a few buzzes and another issue ( another one for the stupid mistake thread ) so I pulled the frets,this time checking the finger board for trueness, and observed the once true board had some major dips and high spots! is rosewod prone to changing its shape overtime ? or did I maybe do a " not as good as I thought " job the first time around ? thanks Jody
Author:  Mark Groza [ Thu Mar 19, 2009 8:56 am ]
Post subject:  Re: has anyione else experienced this with rosewood?
Rosewood is sold alot of times not properly seasoned or aged which causes that problem.All wood has to be properly seasoned and dry to quit moveing around after worked.
Author:  Barry Daniels [ Thu Mar 19, 2009 8:58 am ]
Is the fretboard attached to a neck yet. If not, then a little movement is not unusual.
Author:  Jody [ Thu Mar 19, 2009 2:18 pm ]
the finger board has been attached to the neck for at least 6 months, its is actualy a martin fingerboard, I bought from someone on ebay, it has been around awhile... Jody
Author:  Chris Paulick [ Thu Mar 19, 2009 7:20 pm ]
Get the neck as straight as you can with the truss rod and pull the frets, level the board and fret and level the frets if need be and dress. It will be good practice. Look on the bright side, you don't have to reset the neck. :) If the dips aren't too bad you might get away with just leveling the frets.
Author:  bluescreek [ Thu Mar 19, 2009 8:11 pm ]
If you got this from ebay most of them buy the rejects. Most of these have dips and other issues. There are too many on ebay that sell junk and pass it off as good stuff. Martin rates the offal of the production as 2nds and rejects. Most of the 2nds are used in kits and sold as parts. The rejects are sold in bulk to ebayers.
be aware of your supplier.
Author:  Jody [ Fri Mar 20, 2009 7:42 am ]
Thanks for the responses, I definatly do not need to reset the neck, I had to pull the frets anyways so I can reshape the radius. i didnt know martin had a three tier rating system , ie .. usable ( or first quality ) , seconds ( slight imperfections they dont want to repair ), and rejects ( unusable ?) I am thinking much of the " 2nds" should be repairable, i mean dips and humps should be able to be sanded out . thanks again , Jody
Author:  Chris Paulick [ Fri Mar 20, 2009 8:02 am ]
A lot of the 2nds. and rejects are probably due to color more then anything else.
Author:  Jody [ Sun Mar 22, 2009 1:16 pm ]
I wish it was that easy ! LOL I used a single action truss rod, it made the set up a bit more complicated than when I built the guitar with Frank Finnocchio( we used a double action rod ) fretting gave the neck a back bow , and I could not adjust the neck straight before stringing ! . so I just took a close look at the frets and went on faith , glued the frets in , strung it up, let it settle in. finished the set up and intonation . I had three buzzing frets, I took a little off with a file and some sand paper .My action is about 3/ 32nds on the bass side and about 1/16 on the treble. the playability and sound of the guitar is more than I expected ! Jody
