It is currently Tue Aug 05, 2025 7:33 am
PostPosted: Wed Mar 04, 2009 11:06 pm
I'd like to try to make some simple inlay banding & bindings(rope or checkered pattern). I know there was a book written on it,but, it has been out of print for some time. Does anyone know of another book where I might find such info, something with diagrams?
If you make your own bindings, after you resaw to the desired thickness, what's the best way to remove your bandsaw marks? I don't have a planer. I tried a block plane but the material is hard to hold as it's so thin.
PostPosted: Thu Mar 05, 2009 7:47 pm
No one knows about this?
PostPosted: Thu Mar 05, 2009 7:59 pm
Hi Wyodave
Had this in my links on making such things, may be worth a look in help to your quest.
Hope it is of use.
regards Philip
PostPosted: Thu Mar 05, 2009 8:18 pm
Philip, what is it?
PostPosted: Fri Mar 06, 2009 8:21 am
I am sorry :oops:
The link is below
http://woodtreks.com/learn-how-to-make- ... nding/529/
Top right on the page shows other links on the subject that are worth a look at to.
regards Philip
PostPosted: Fri Mar 06, 2009 2:48 pm
Yea Philip, I found that a while back...very interesting.
PostPosted: Fri Mar 06, 2009 3:12 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
Check out www.byersguitars.com and the book Making Master Guitars.
Mike Collins
PostPosted: Fri Mar 06, 2009 3:18 pm
Last Name: Collins
City: Argyle
State: New York
Try gluing some 80 grit paper to both jaws of your vise.
Then slowly puul the binding piece through the jaws.
Go slow,do not squeeze the piece to hard.
A scraper set upon a bench so that a piece of binding can be drawn under it also works.
to do this clamp the scraper between to blocks of wood and clamp those blocks to the bench
Mike Collins
PostPosted: Fri Mar 06, 2009 3:20 pm
Last Name: Collins
City: Argyle
State: New York
[quote wyodave"]If you make your own bindings, after you resaw to the desired thickness, what's the best way to remove your bandsaw marks? I don't have a planer. I tried a block plane but the material is hard to hold as it's so thin.
Then slowly pull the binding piece through the jaws.
Mike Collins
PostPosted: Fri Mar 06, 2009 3:24 pm
I recall that Joshua French had a jig that holds a scraper, made from a plane blade, in the correct position to scrape bindings and purflings. It was adjustable for different thicknesses, and held the blade at just the correct angle.
I found it, it is in this thread: viewtopic.php?f=10102&t=13586&p=190765&hilit=plane+blade#p190765
PostPosted: Fri Mar 06, 2009 4:33 pm
Just a thought, did you try searching the web for stuff on Marquetry? I see some of these things called marquetry purflings from time to time. Just wanted to throw that out there.
Rob
PostPosted: Fri Mar 06, 2009 8:32 pm
If you have a workbench you could use just enough double stick tape to hold your bindings to the bench surface and then a nice sanding block with several grits of paper to smooth out any marks. This is what I do when working with thin material. The key is that the double stick is pretty strong and don't use too much.
http://www.booneguitars.com
https://www.facebook.com/pages/Stephen-Boone-guitar-builder/488208541257210
PostPosted: Fri Mar 06, 2009 8:40 pm
There's a tutorial on MIMF by Mick Lazar.
Users browsing this forum: No registered users and 50 guests
