whats the best way to fix a finish sand through on the edge
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=21247
Author:  joekelly9692 [ Fri Feb 27, 2009 4:41 pm ]
Post subject:  whats the best way to fix a finish sand through on the edge
hi all......i started fine sanding my guitar that i sprayed with colortone sanding sealer and clear topcoat and i micromeshed back through to the sanding sealer right on the edge could you guys give me any suggestions on the best way to deal with this.....could i try airbrushing some lacquer on there? as always thanks for help guys......joe
Author:  Michael Dale Payne [ Fri Feb 27, 2009 4:47 pm ]
Post subject:  Re: whats the best way to fix a finish sand through on the edge
I would air brush 3-4 coats over lap at least a half an inch allow to cure the relevel that area
Author:  joekelly9692 [ Fri Feb 27, 2009 4:54 pm ]
thanks Michael .....i will give this a blast tommorow......
