Bridge clamp...how?
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=21207
Author:  SkyHigh [ Wed Feb 25, 2009 11:21 am ]
Post subject:  Bridge clamp...how?
What method do you use to glue/clamp your bridge?
I see some people use clamps with long throat and some use clamp jig thru the pin holes. Pros and Cons of each?
Thanks, David
Author:  Michael Dale Payne [ Wed Feb 25, 2009 12:00 pm ]
Post subject:  Re: Bridge clamp...how?
One deep throated "C" clamp and a home made bridge clamping caul patterned after the Stewmac bridge clamping caul
Author:  Robbie O'Brien [ Wed Feb 25, 2009 2:27 pm ]
I used to use the clamps through the soundhole until I used a vacuum clamp. There was no turning back.
Author:  Robbie O'Brien [ Wed Feb 25, 2009 2:29 pm ]
Author:  Frei [ Wed Feb 25, 2009 2:46 pm ]
Has anyone made a home-made C clamp out of plywood for this? Could it be made strong enough?
Author:  matti [ Wed Feb 25, 2009 2:50 pm ]
for the next one I plan to use the LMI 'fox bridge clamp' but haven't used it before. Seems like a simple enough method anyways
Matt
Author:  Doug Sawyer [ Wed Feb 25, 2009 3:00 pm ]
I made a cam clamp once to glue the bridge on a soprano ukulele. It wasn't hard to make out of scrap wood and a little 3/4 by 1/8 inch steel. Since I made it for this uke, I designed it to clear the top braces. It worked well.
Doug
Author:  Bill Greene [ Wed Feb 25, 2009 3:03 pm ]
Ditto on the vacuum clamp. Easy, thorough, etc.
Author:  Michael Dale Payne [ Wed Feb 25, 2009 3:04 pm ]
with the right treaded inserts you could make one but I assume you mean on that is both the clamp and lower and upper caul all in one but the cost of a single C-clamp and build your own upper win adjustable caul from ply, inserts screws and cork and a ply bridgeplate caul would far less work.
Author:  Sylvan [ Wed Feb 25, 2009 3:21 pm ]
Here is one of the clamps I use:
Author:  stan thomison [ Wed Feb 25, 2009 3:39 pm ]
As Robbie, did the clamps and for last 3 years vacuum, never do to it any other way (well unless breaks or run out of power, so good to know both)
Author:  jfmckenna [ Wed Feb 25, 2009 4:28 pm ]
I always use two bolts through the 1'st and 6th string holes that are the exact same size as the hole and lightly tighten them to hold for positioning and then use 3 clamps with cauls shaped for the wings and the center.
Author:  Terence Kennedy [ Wed Feb 25, 2009 5:03 pm ]
I started with a central clamp and caul with two long clamps on the wings. Now I use the StewMac clamp. Pretty much the same principle as Sylvan's cool clamp. Quick, so it works well for hide glue. Plenty of access for clean up. You need a rigid central clamp or else the outrigger screws can spring the central clamp open and reduce the pressure.
I hold the bridge with two brads in the saddle slot. Drilling the holes before gluing as you have to do with the Fox clamp never appealed to me.
Terry
Author:  Michael Dale Payne [ Wed Feb 25, 2009 5:07 pm ]
Terry
Yep my rig is the same but I made ny own bridge caul
Author:  Arnt Rian [ Wed Feb 25, 2009 5:21 pm ]
I use the same set up as Terence. I can't tell from the picture if he has removed the plastic cap on the end of the clamp screw, which I did. The end of the screw is ball shaped, and I drilled a matching shallow "dent" in the middle of the bridge wing clamp. This will keep the screw on the C-clamp centered on the bridge clamp and keep it from moving as you apply pressure. One more thing to keep in mind with this set up is that you need fairly rigid bridge plate caul to counter the pressure over the bridge wings, to avoid distorting these areas during clamping.
Author:  Terence Kennedy [ Wed Feb 25, 2009 8:06 pm ]
Yep I removed the plastic thing and drilled a recess in the caul for the ball end of the clamp. I think I got the idea from a post by Arnt!! I just use a 3/4" caul exactly the same shape as the bridge plate with a radius on the soundboard side. I don't have any outriggers that span the X and come up under the wings. (Used to when I used three separate clamps) Do any of you guys do that?
Terry
