Binding Jig finished http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=21131 |
Author: | Lars Stahl [ Fri Feb 20, 2009 11:18 am ] |
Post subject: | Binding Jig finished |
Ok, so I could not wait. did the binding jig myself ![]() ![]() ![]() Lars. Attachment: underneath.jpg Attachment: jig.jpg
Author: | Darrin D Oilar [ Fri Feb 20, 2009 11:44 am ] |
Post subject: | Re: Binding Jig finished |
Looks great Lars!! It sounds like it works great too. At least the jig/fixture building slows down at some point. Right??? Tell me it does. Darrin |
Author: | Hesh [ Fri Feb 20, 2009 11:49 am ] |
Good going Lars bro your jig looks fantastic! ![]() ![]() ![]() ![]() ![]() ![]() |
Author: | Mike OMelia [ Fri Feb 20, 2009 12:14 pm ] |
Thats nice Lars. Real spacesaver I may actually build one of those... especially for doing harp guitars. The arm on the williams won't reach and I have to constantly reposition the base. |
Author: | SteveSmith [ Fri Feb 20, 2009 12:19 pm ] |
Way to go Lars, looks good! It sure feels good when that first binding channel is done, doesn't it? ![]() |
Author: | Dave Fifield [ Fri Feb 20, 2009 1:36 pm ] |
Nice jig Lars! Aren't you worried that the cloth will bunch up under the holding jig and cause height variations when you route? Dave F. |
Author: | Lars Stahl [ Fri Feb 20, 2009 2:21 pm ] |
Thank you all, Yes does feel great, Dave , didn´t even think of this ! ![]() also just pun in the endgraft. so getting closer to finishline. ![]() just got some velcro or whatever its called for having underneath the sandpaper on the drumsander. will fix that thing next hmm. like I said it never ends. ![]() Lars |
Author: | Lars Stahl [ Fri Feb 20, 2009 6:52 pm ] |
just glued in the bindings and purf. scaaary !! hmm cant wait to get the tejp off. ![]() |
Author: | joel Thompson [ Fri Feb 20, 2009 8:17 pm ] |
anyone got any plans for binding jig i really need to make as binding channels is worst hated job, Joel. |
Author: | Lars Stahl [ Sat Feb 21, 2009 6:46 pm ] |
Joel. Its not hard at all to build, you wont need a plan to build it !! draw a shape of a body. , look at the wood I used for the guitarholders, and screws. Get the rollers that it glides on on the hardwarestore. build a to walls with bottom, place the gliders on the sides (about 3-4 inches up from the botttom ) then make another walls with bottom and screw the L-trimmer onto it, on the bottom of this one frill a hole that is just a bit bigger that the cutter, and underneath place the thingy pictured, that the guitar will run on. I used hard plastic, drilled a hole the same size as on the plate the L-trimmer sits on then shaped it on the belt sander left about 7mm straight so the guitar has a place to run on. Lars. Attachment: P180209_18.22[02].JPG Attachment: P180209_18.22[01].JPG
Author: | SteveSmith [ Sat Feb 21, 2009 8:30 pm ] |
Joel, there's some more information in this threadhttp://luthiersforum.com/forum/viewtopic.php?f=10101&t=20790. If you need more information just ask. |
Author: | Chris Paulick [ Mon Feb 23, 2009 7:04 pm ] |
Good job Lars. But I think you will need a sled with cutaways if you want to build a cutaway. LMI sales plans if you need a plan. |
Author: | Randolph [ Mon Feb 23, 2009 7:16 pm ] |
Nice job Lars!! ![]() ![]() ![]() ![]() ![]() |
Author: | Chris Paulick [ Mon Feb 23, 2009 7:45 pm ] |
Here's another carriage design. It's from the LMI plans except I used carriage bolts and the wing nuts as they are much cheaper then buying plastic knobs and 1/4" bushings. It works fine. The side pressure isn't that tight. You snug it up all the way around and make the sides square to the table. The carriage works great as a holder for doing other jobs too. If you don't want it to move you just clamp it to the work bench. Lars, I hope you don't mind me posting these pics? I just want to show some options for the carriage. |
Author: | Randolph [ Tue Feb 24, 2009 12:15 pm ] |
Thanks for the pictures, Chris. I get it now. There really is no lateral pressure on the guitar. The box is held in placd by the adjustable blocks that it sits on. The lateral adjustment is just to keep the guitar from moving in the carriage (not to hold it up). |
Author: | Chris Paulick [ Tue Feb 24, 2009 12:42 pm ] |
The vertical piece is 5" X 1 1/2", the horizontal is 4" X 1 1/2" and the block is 2" X 1 1/2" all X 3/4" . The base outline is about 1 1/2"-2" smaller then a Dred or in other words the arms over hang the base by that distance. Slotting the pieces takes the longest time. I cut mine in a mini mill so it was pretty easy. I found those wingnut/washer combonation at Home Depot. They are used for hurricane proofing windows. You might be able to find them there. I use them for a lot of jigs as they are cheaper then knobs. |
Author: | Randolph [ Tue Feb 24, 2009 1:56 pm ] |
Awesome!!! The rest looks easy. Thanks ![]() |
