String Size
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=20969
Author:  CecilJ [ Tue Feb 10, 2009 6:01 am ]
Post subject:  String Size
I assume that thicker strings are louder.
If you feel that your guitar is lacking in some freequency area does it make sense to increase the string size for that area.
For example: If your bass seems to be less than balanced with the higher frequencies would it make sense to use a little thicker strings on the 2 or 3 lower ones?
Author:  oli-lgw [ Tue Feb 10, 2009 7:07 pm ]
Post subject:  Re: String Size
I might well be wrong, but I don't think that bigger strings will get you what you want. Out of curiosity, what kind/brand of guitar is it?
Bigger strings will give you more tension, therefore more output, more volume, and depending what kind of strings they are you will change the tone a bit. But definition, or lack of, is due (I believe) to the guitar itself, the bracings, the materials, etc.... If you put bigger strings on, let say, your 6th and 5th strings, these strings are maybe going to be louder but you are not going to increase the bass response of the instrument.... theyre gonna be louder whatever notes you play on them ;)
As I said, I might be wrong, but thats from what I have seen and heard so far...
