It is currently Mon Aug 04, 2025 6:58 pm
 Post subject: Playing before finishing
PostPosted: Thu Feb 05, 2009 10:32 pm
Do you play your newly built guitars before the finish is applied to hear the difference in sound? And those that have.Did you find a big difference in sound before and after?
PostPosted: Fri Feb 06, 2009 12:05 am
I string mine up before I finish. I use those hollow screws thru the bridge pins (Stewmac). Mainly I'm checking intonation and neck angle and feel to make sure I've got it close. On my archtops it's easier.
As for sound... it's really difficult to judge. I notice changes for the first month a guitar is strung up. It's really difficult to isolate the effect of finish from everything else. Just my opinion....
PostPosted: Fri Feb 06, 2009 7:13 am
I did that on the first two or three that I built. For beginners I think it is valuable learning, you can carve some bracing and thin the top and learn a little.
However the changes in sound when you apply finish and properly glue down the bridge and fretboard are significant, so it's not what I do anymore.
David White, Toronto
Users browsing this forum: No registered users and 42 guests
