The science of sound and acoustic guitars
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=20579
Author:  Jeremy Douglas [ Mon Jan 19, 2009 5:00 pm ]
Post subject:  The science of sound and acoustic guitars
There seems to be plenty of resources on how to build guitars but can anyone point me to some resources for the science part of it? I'm thinking about things like damping, Chladni-patterns, how density and stiffness affect sound transmission, etc. I figured surely there's some scientific area of study for things like how the hardness of the saddle material or the weight of the bridge affects the sound. Has anyone(...like Mr. Carruth) written book like this?
Author:  David Collins [ Mon Jan 19, 2009 5:45 pm ]
Post subject:  Re: The science of sound and acoustic guitars
How about the Rossing and Fletcher books, pretty much with the titles you listed? "Science of Sound" but Thomas Rossing, and "Physics of Musical Instruments" by Rossing and Fletcher. I have both and there is a lot of overlapping information. Not sure which I would recommend more though. I'll look through them tonight, and try to get back with an opinion which may be the better choice if you were only to buy one. Keep in mind that they are college textbooks, and do require at least a decent foundation in algebra, and can be much easier to understand with a bit of basic physics knowledge.
Neither book is directly focused on the guitar either, so they will not go in to the minutia of guitar design. They are an invaluable resource in my opinion though, and can set you in a good direction with understanding strings, transmission of waves, and lots of basics that can really help you understand more.
Author:  John Bushouse [ Mon Jan 19, 2009 6:26 pm ]
Left Brain Lutherie ought to fit the bill.
From the website:
Quote:
This is not a step-by-step manual for making an ukulele or guitar from beginning to end. Please don't buy this book if that's the only kind of information that you're looking for.
This book is about trying to understand more about physics and engineering concepts as they are actually applied to instrument building. If you have already built several instruments and want more consistency, better mechanical stability and a deeper understanding of the effects of string load on your instrument (and many other subjects as well), this is the book for you.
I believe that if you take the time to read and think about the information herein and practice using the spreadsheets to understand more about your wood and building, that you will be considerably more consistent with respect to the type of sound you wish to achieve and the long-term stability of the instrument as well.
There is a lot to think about in the book and it may take some time to become comfortable with some of the calculations. In all honesty, it took me a fair amount of time to research and write the book since I am not facile in either physics or mathematics. Please be patient and take the time to work through the different problems and spreadsheets. In the end, I'm sure that both improvement and understanding will result.
In the following chapters, I apply introductory physics and technology to instrument making in a manner which can be used and tested by anyone with a knowledge of high school mathematics, a home computer and a few easily obtained or constructed instruments. I show experimental setups in sufficient detail so that those reading this book can duplicate and extend these studies. These setups are as simple as possible while maintaining an adequate level of accuracy and precision for the experiment at hand. For example, the top deflections studies only require a piece of 2”x4”, a moderately sized piece of plywood for the base, several different sized PVC pipe fittings, an inexpensive dial micrometer, a foot long 1/4” diameter metal rod, some calibrated weights (I used fishing sinkers), small wood scraps and the wooden plates of interest – hardly a room filled with $10,000 worth of science equipment.
I have tried to make the format of the book practical and readable: large pages, 24 lb stock paper for durability, relatively large print, a spiral binding so that the book can lie flat on a workbench or beside the computer without effort and a CD containing both spreadsheets for data manipulation / analysis and many color images of physical measurement setups.
Page 126 discusses bridge dimensions, for example. I'm pretty sure Al has a copy of the book.
Author:  Jeremy Douglas [ Mon Jan 19, 2009 8:11 pm ]
Thanks David. I got an 'A' in college algebra but that was a few years ago, hopefully I remember more from it than I do the two years of French I took.
John, Left Brain Lutherie sound very interesting. I'll have to get that one for sure.
Author:  Eurospruce [ Tue Jan 20, 2009 5:28 am ]
Hi,
there is a doctoral thesis about "The acoustics and and psychoacoustics of the guitar" by Dr. Howard Wright on my homepage (sroll down) for free downloading, maybe this paper is interesting for you.
Best
Martin
Author:  Jeremy Douglas [ Tue Jan 20, 2009 10:18 pm ]
Thanks Martin, I went ahead and downloaded it.
