It is currently Mon Aug 04, 2025 6:57 pm
 Post subject: alder for necks?
PostPosted: Wed Jan 21, 2009 11:23 pm
i know that we've had "alternative neck woods" conversations before, but i don't recall how many people used alder. looking through a back issue of fine woodworking, it suggests alder to be an often over looked and stable hardwood. it's all over the place in the electric guitar world. any reason it wouldn't work in the acoustic world?
if alder is a good idea, and your canadian, any suggestions about suppliers? the one here in winnipeg wants a fortune for what is supposed to be an affordable wood.
phil
 Post subject: Re: alder for necks?
PostPosted: Thu Jan 22, 2009 1:53 am
I did an alder neck on a crossover nylon string guitar. It was a little soft but it's holding up fine. I would carbon reinforce it for steel strings. There are several types of alder and the density could vary a lot.
Ken Franklin
clumsy yet persistent
PostPosted: Thu Jan 22, 2009 6:06 am
I raised this question a while back after reading that same FWW article. If you search the archives, you should find that thread.
I will probably try alder for necks at some point, but it will be a while before I get around to it. Carvin uses it for electrics.
Todd Rose
Ithaca, NY
PostPosted: Thu Jan 22, 2009 10:06 am
Alder is a pretty common wood used in guitar building.I don't see any problem useing it for a neck.It's simular to maple anyway.It is a good tonewood.
Users browsing this forum: No registered users and 39 guests
