It is currently Mon Aug 04, 2025 1:47 pm
 Post subject: Compressor is on the way
PostPosted: Thu Jan 08, 2009 10:50 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
So, I need a good spray gun. And I am SO ready for this. Got one guitarjust waiting to be sprayed. So reccomend away plz!
PostPosted: Fri Jan 09, 2009 12:13 am
First name: Darrin
Last Name: Oilar
City: Cottonwood
Zip/Postal Code: 96022
I guess like everything, it all depends on what you mean by "good". Sata is excellent quality. But you'll pay for it. Don't forget filters and water traps as well as respirator etc.
Darrin
PostPosted: Fri Jan 09, 2009 1:15 am
Last Name: O'Melia
City: Huntsville
State: Alabama
Yes, I have heard about Sata. More info appropriate for Nitro spraying?
PostPosted: Fri Jan 09, 2009 11:00 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Hmmmm! Maybe I have not paid my dues?? Surely one of you has some good info on an appropriate spray gun?
Mike idunno
PostPosted: Fri Jan 09, 2009 11:36 pm
Mike idunno
Weren't you paying attention to my HVLP vs. Old School thread here: viewtopic.php?f=10101&t=20074&p=283183&hilit=HVLP+vs.+siphon#p283183
Lot's of good info. I bought the asturo and like it but I'm spraying waterborne, not nitro.
PostPosted: Fri Jan 09, 2009 11:41 pm
First name: Kenneth
Last Name: Casper
City: Northville
Country: U.S.A
I have an Asturo as well. Love it. My compressor is a 24 gallon unit and runs it fine. The thread mentioned by Andy is a good one. There were a couple of threads on HVLP equipment running about the same time just recently. Give them a good read.
Ken
http://www.casperguitar.com
PostPosted: Fri Jan 09, 2009 11:57 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I am paying attention now! Thanks
Andy Birko wrote:
Mike idunno
PostPosted: Sat Jan 10, 2009 8:46 am
this is a topic that will have some good info in it. For one , you have pressurized cups , gravity feed , HVLP . I have a Sata and I also bought a Sata knock off at Grizzly. To be honest , I use the Grizzly as my undercoat ( sealer gun ) Sata is my finish sprayer. I use a touch upp gun , they are smaller but carry all the finish you need. I like them as the spray is more controllable .
Now along with the gun , it is the finish that you use. I use Behlen or Mowhawk products. Lacquers from Home Depot and Lowes don't have as much solid content. The end result of the finish begins with the prep. Don't short cut the finishing . You don't need to have the highest priced gun , but you do need a fair grade of one.
http://grizzly.com/products/searchresul ... pray%20gun
I also have the contained unit. it has its own air source . It is great in that I don't have to worry about condensation or oil in the air. Getting an air compressor is only half the battle as you need to get the right filters . Your air has to be dry and oil free. I have in the shop a 50 gal 5 HP unit. I have 2 filters installed ,one is a water separator and the other filters out oil. I use a 2nd set of filters at my spray outlet so I am double filtered. If I were doing more finishing I would install a refrigerated dryer. Once you figure out what you need , practice. If you have a auto repair friend , he may be able to help. Acrylic lacquers work much like Nitro and you should be able to get some good advice on equipment there
john
PostPosted: Sat Jan 10, 2009 12:06 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Hey John, thanks. When you say second set of filters, just where are they?
PostPosted: Sat Jan 10, 2009 12:08 pm
I have a DeVilbiss SRi and it's a fine tool
Terry
PostPosted: Mon Jan 12, 2009 9:26 am
City: Tyler
If you'd rather spend money elsewhere, in my opinion, there is no need to buy expensive sprayguns to spray nitro. It is a very forgiving finish to spray and just about any gun will work.
