It is currently Mon Aug 04, 2025 1:47 pm
PostPosted: Sun Jan 11, 2009 5:46 pm
First name: Douglas
Last Name: Ingram
City: Lorette
State: Manitoba
So as not to hijack another thread, I though that it would be cool to see some of the old fashioned guitars that we've been working on. I'm working on some SE117's and a Panormo, and Mike Collins is working on a Lacote and an old Martin. Mike, I want to see what you've been up to!
Here are mine. WRC tops and Ash bodies.
http://redrivercanoe.ca/
PostPosted: Sun Jan 11, 2009 6:28 pm
First name: David
Last Name: LaPlante
Taking a break from classicals, I did a restoration on an 1840s Martin and Coupa guitar.
The guitar had been "repaired" by grafting on the slotted peg head from another guitar.
Here is the remaining "dart" once the unoriginal head was taken off. You can see the remains of the original modified bridal joint and how the previous "restorer" cut through it.
Measuring the width of the dart at the level of the new peg head.
And the angle of the rear face of the replacement
Checking the template
Making the initial cuts
Visible are the rosewood "bushings" set into the mahogany of the head (this guitar has a Cuban mahogany neck in contrast to Spanish cedar which was used on later Martins) as was the case on 19th century martins which used friction pegs
Detail of the recess
PostPosted: Sun Jan 11, 2009 6:43 pm
First name: David
Last Name: LaPlante
Here is the peghead showing the Brazilian rosewood head veneer, pattern (developed from another 1840s example)
and the original nickel silver nut.
Final fitting
Clamping and glueing with fish glue
After careful shaping, sanding, coloring and french polish
I fitted a set of reproduction 19th century Martin style pegs which were made by UK luthier Bruce Brook to my specs.
In addition I made and fitted a proper 1840s style Martin tie bridge:
The completed guitar:
PostPosted: Sun Jan 11, 2009 7:49 pm
How did you cut the V slot in the headstock?? :ugeek:
PostPosted: Sun Jan 11, 2009 7:55 pm
First name: David
Last Name: LaPlante
With the knives shown and a small chisel.
Here are some details of the Headstock:
As well as the replicated bridge:
www.guitarsbydavidlaplante.com
Last edited by David LaPlante on Sun Jan 11, 2009 8:14 pm, edited 1 time in total.
PostPosted: Sun Jan 11, 2009 8:13 pm
First name: George
City: Seattle
Douglas -- That's a nice trio you have there and I love the rosettes. Those old style guitars are wonderful.
David -- Wow! Beautiful work. That's one lucky guitar to have found its way to your shop after all these years. Well done.
George :-)
PostPosted: Sun Jan 11, 2009 8:45 pm
Nice looking guitars!
Hi David,
Since you were making a new peghead why didn't you take it back to the modified bridle joint?
PostPosted: Sun Jan 11, 2009 9:06 pm
First name: David
Last Name: LaPlante
The previous "restorer" had not only cut the original peghead
(or the remains thereof) off along the edges of the "dart", but had reduced the size of the "dart" to the point where re-establishing the original bridle joint configuration would not have left much wood at all.
I decided to leave what remained alone and to do a mortised "V" joint (a la' Hauser). It would be the strongest joint choice and would restore as much of the original look as could be done with what was left.
PostPosted: Sun Jan 11, 2009 10:20 pm
Can you post some soundclips?
PostPosted: Mon Jan 12, 2009 4:06 pm
First name: Douglas
Last Name: Ingram
City: Lorette
State: Manitoba
David,
I'm really impressed by the museum grade work that you're doing on that old Martin. But there's no surprise in that. Looks like a fascinating guitar, can you tell us more?
PostPosted: Tue Jan 13, 2009 1:22 am
David, I would expect nothing less than the highest quality from your shop. David is a historian as well as an artisan, just wish I lived closer to learn as much as possible from him. Great work David. Nice to see old traditions being preserved. And there are many others here who do the same, my hat's off to all of you.
Bruce
Bruce Herrmann
"What lies behind us and what lies before us are tiny matters compared to what lies within us."
