It is currently Wed Aug 06, 2025 6:10 am
PostPosted: Sun Dec 07, 2008 11:24 pm
I started back to work Friday and worked Saturday but got some shop time today and worked on my latest side project. A couple more hours and a couple of springs and set screws and I should be finished.
PostPosted: Sun Dec 07, 2008 11:49 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I know, some photos would be nice, but was too busy. I got the kerfed linings glued to the harp guitar body. Really starting to look like a real harp guitar! As soon as I can, I will post some pics, especially of how I bound the harp neck sides to the neck block. Too cool! Used Hofffman's idea.
PostPosted: Mon Dec 08, 2008 8:35 am
I didn't get much shop time this weekend but the 1/16" downcut spiral bit and the bwb wood purfling came in Friday so I was able to finish up the rosette. I also drilled and tapped the head block for the set screws for the Doolin-type neck joint. I had some 1/2" long 1/4-28 set screws I thought I'd use but the maple didn't tap very well for the fine threads so I put a layer of epoxy in the holes and will try re-tapping tonight. I'm still struggling with the logo design.
PostPosted: Mon Dec 08, 2008 8:36 am
Very bad binding that's what I did managed to close a lot of the gaps by wicking thin super glue in and clamping either with some large spool clamps or a sash cramp just levelling now hence the post on finishes
Formerly JJH
PostPosted: Mon Dec 08, 2008 10:02 am
I cut some really nice spruce - a lovely blue spruce Christmas tree, that is, from the top of our hill!
Todd Rose
Ithaca, NY
PostPosted: Mon Dec 08, 2008 11:22 am
I upgraded my bending iron to using a charcoal starter, instead of a soldering iron. Much faster and easier to control.
Then I bent my purflings for my rosette assembly for #2.
Here is the bent wheat.
Here is all the bent purflings, including some I ended up not using.
Here is the assembled rosette. The guitar has EIR back and sides, so the alternating tiles are EIR, which is my "trademark" rosette design. The outer and inner rings are changeable, as are the dividers between the tiles.
Next I prepared the top to receive the rosette.
Clearing the channel took me about 25 or 30 minutes. I had one gouge out, in the bottom of the channel. You can see it sitting on the rosette board in the upper right. I glued it back in with hide glue, just for practice, and to keep the rosette channel fairly flat in the bottom. Worked fine. Then I transferred the rosette to the top, and used the extended open time Titebond, that I saw in Robbie's Tips du Jour. (We used to call our gutar ensemble "The Group du Jour" :D It still dries up too fast. I don't want to use CA, or epoxy. I actually like to get a bit of swell working in the wood, to help fill the tiny gaps. Anyway as I was finishing, I noticed that i missed an alternation in the pattern. [headinwall] [headinwall] Tore it out, washed the tiles off, and threw away the purflings which were a mess. gaah
PostPosted: Mon Dec 08, 2008 11:28 am
Actually, I used Chris Paulick's videos as the guide to make my own micro circle cutter. And it came out great. The tele knob is a bit hard to turn, but it seems to work ok.
PostPosted: Mon Dec 08, 2008 11:31 am
Great looking rosette Waddy! Nice wheat.
PostPosted: Mon Dec 08, 2008 2:51 pm
First name: Kenneth
Last Name: Casper
City: Northville
Country: U.S.A
Got the rims leveled and the perfling/binding channels cut on my OM. Also routed out the cavity for the end graft. Explored some options from forum members for gluing in the perfling/abalone/binding--thank you very much!
Ken
http://www.casperguitar.com
PostPosted: Mon Dec 08, 2008 4:50 pm
I leveled and glued up a ash laminated neck i'm building for a dread.
PostPosted: Mon Dec 08, 2008 5:49 pm
Dug up and replaced 80' of water line from the meter to the house [headinwall] ya got to love 80 year old houses Eat Drink
PostPosted: Mon Dec 08, 2008 7:59 pm
I thought I finished the last paper of my graduate career, but then I decided to start calling around to a few school counseling programs today. ;)
I also sat in on classes from a few local martial arts places. I want a black belt :D
PostPosted: Mon Dec 08, 2008 8:56 pm
Finally finished this OM/DQM which had been kicking my butt for about three months. Had to strip and refinish the top...don't ask...and just couldn't get it right. Had to put my patience to the test but finally gave in and took my time and wow what a great guitar. Wish it didn't have to go. Sorry for the poor pics but just shot them in the shop with flash and no tripod. Its Carpathian Spruce/Quilted Honduran Mahogany/BRW peghead overlay/Curly Maple bindings/ebony bridge and fingerboard/violet inlay at 12th fret. I'll try to take a closeup of that later. WHEEEEEWWWWWWW!!! Glad this one's done. Thanks to all the folks who post on here. It really helps me alot. Glad the OLF is here!!
"We might not be big but we sure are slow"
PostPosted: Mon Dec 08, 2008 9:06 pm
Didn't get much done besides this Dreadnaught mold...
PostPosted: Mon Dec 08, 2008 10:28 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Dave, that is a beautiful mold!
Here are some harp guitar progress pics. Not pictured is the almost finished back. The last picture offers a reason why it is taking me so long. ;)
See if you can spot a mistake I made (sure, there are plenty, but I am talking about a big mistake.) One I will not do anything about since it really does not matter to me. Note the joint I used to bind the harp neck to the neck block. Love that SC reverse kerfed lining! Beautiful stuff.
PostPosted: Mon Dec 08, 2008 10:59 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
PS: I meant to offer appropriate credit for the harp neck joint: Charles Hoffman.
PostPosted: Tue Dec 09, 2008 6:18 am
Looks like my old Springer, "Buck".
PostPosted: Tue Dec 09, 2008 7:00 am
Mike, that's a great picture of your son and the dog. Looks just like my youngest son and our dog. He is always using her for a pillow. Looks like we even have the same dog bed! LOL
________________
Jeremy Vonk
PostPosted: Tue Dec 09, 2008 9:19 pm
First name: Jeff
Last Name: Hewitt
Zip/Postal Code: 37312
Hi Waddy,
What kind of heat controller do have on your bending iron?
PostPosted: Tue Dec 09, 2008 10:23 pm
The ultimate! A Harbor Freight Router Speed control. Works fine.
PostPosted: Tue Dec 09, 2008 10:36 pm
First name: Jeff
Last Name: Hewitt
Thats what I thought it was....Thanks Waddy!
Users browsing this forum: guitarjtb and 22 guests
