That's the way I make them, too. If you mirror your neck template along the board at the same distance from the edge, the figure and the angle of the grain in the two blanks will be very similar, and even though it is not book matching it looks almost like that (I believe the English term is slip matching?). I also believe it should be good for the neck’s stability as any movement in one of the laminates will be opposite in the other, thereby canceling each other out; that’s the idea, anyways.
I have made them both this way ///\\\ and this way \\\/// (fingerboard on top), not sure which is the most stable orientation, but in the latter the grain will follow the shape of a tapered heel, which looks nice IMO.
_________________ Rian Gitar og Mandolin
