Bosch Colt opinions http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=19295 |
Author: | JimWomack [ Thu Oct 23, 2008 4:17 pm ] |
Post subject: | Bosch Colt opinions |
I'm going to pick up another laminate trimmer this weekend. After looking at all the usual suspects, I've decided to pick up a Colt. My question is this: Is it worth the extra money to go with the variable speed version... or is the single speed model adequate. |
Author: | Cartierusm [ Thu Oct 23, 2008 5:15 pm ] |
Post subject: | Re: Bosch Colt opinions |
Definately go for the Variable speed option. And accept nothing less than Bosch. Think and Tinker are in the process of coming out with precision collets. I have their Porter Cable Precision Collets and they rock. This of course is only neccessary for tight inlay work. |
Author: | Rod True [ Thu Oct 23, 2008 5:49 pm ] |
I just picked up a Bosch Colt without the variable speed and I'm told I'm getting two more for Christmas ![]() I got them at $50 so I couldn't pass that up. I will not use anything bigger then 1/4" bit on a laminate trimmer so anything bigger I tend to use my Bosch 1617 with variable speed. But if you don't already have a router with variable speed, spend the $ and get one. |
Author: | LRegnier [ Thu Oct 23, 2008 8:33 pm ] |
Hi Jim, I had a Bosch Colt for about a week, then I returned it to the store. The lock system to prevent the chuck from moving up/down is a very poor design. I almost lost a couple of guitars with the Bosch, I don't recommend it. Try a porter cable, or even the Home Depot Ridgid. I ended up buying the Ridgid because it was variable speed, came with a bunch of handy options, runs smooth and quite, and I love the soft start feature. With the soft start you don't get a that jolt when you start the router. The only drawback with the Ridgid is the round base, you need to have a good solid hand on it when used, or make a new base to your liking. Good luck with your selection. Regards - Luc |
Author: | Rod True [ Thu Oct 23, 2008 9:44 pm ] |
Filippo, these were recently on sale last weekend a a local tools store in my town. They are one sale for the month of October for $59.99 and last weekend they were on for $49.99. |
Author: | j.Brown [ Thu Oct 23, 2008 10:46 pm ] |
LRegnier wrote: Hi Jim, I had a Bosch Colt for about a week, then I returned it to the store. The lock system to prevent the chuck from moving up/down is a very poor design. I almost lost a couple of guitars with the Bosch, I don't recommend it... Regards - Luc I've never had an issue with mine. Seems to work perfectly for every use I've put it to. Powerful, accurate, easy to use. Others are fine, too, but I'd never recommend against the colt. -j. |
Author: | John Mayes [ Thu Oct 23, 2008 11:02 pm ] |
I have a couple and they are nice Lam trimmers... I use them and my Makitas more than anything if I need a lam trimer. I use one of my dozen or so 1617EVS bosch routers for big stuff. |
Author: | Mike OMelia [ Thu Oct 23, 2008 11:04 pm ] |
I have no idea why the naysayers had problems. I LOVE my Bosch Colt and LOVE the variable speed. Works great on the Williams Binding Jig too. If someone REALLy knows where I can pick one more up for that low price ($60) tell me. I will just leave one attached to the binding jig. Mike |
Author: | DanielC [ Thu Oct 23, 2008 11:31 pm ] |
I like the home depot rigid also, only problem had with it is that i don't care for the on/off toggle switch and i though it was louder than any other laminate trimmer i used before |
Author: | JimWomack [ Fri Oct 24, 2008 8:17 am ] |
Thanks for all the replys, guys. I was also considering the PC, but it was my understanding that the 310 had been discontinued. Sounds like the variable speed is worth the extra bucks, so I'll go that route then. I believe the Colt has the soft start feature, same as the the PCs. |
Author: | Chris Paulick [ Fri Oct 24, 2008 8:29 pm ] |
The 310 can be had at Amazon for about $165. Well at least they were a month ago. The 7310 locking system can be improved by replacing the spring with a lock washer. You know you can get a router speed control at Harbor Freight for $5 that you can use with your heat blanket and while you're there get a foot switch too. That's just some other options. ![]() |
Author: | Kent Chasson [ Sat Oct 25, 2008 12:45 am ] |
I had a bosch colt and the bearings were shot about a month after the 1 yr warranty was up. I bought the bosch because the locking mechanism seemed better than the PC. I was replacing a PC after about 15 yrs of steady use. Only reason it quit was because it got dropped on a concrete floor. Back to PC for me. |
Author: | Jeffrey L. Suits [ Sat Oct 25, 2008 11:59 am ] |
Kent Chasson wrote: I had a bosch colt and the bearings were shot about a month after the 1 yr warranty was up. I bought the bosch because the locking mechanism seemed better than the PC. I was replacing a PC after about 15 yrs of steady use. Only reason it quit was because it got dropped on a concrete floor. Back to PC for me. Hmm...I got a Colt, and it's running VERY hot, very quickly--I suspect bearings. Other than that, I like it. Got it for $40, Craigslist. Guess I should fill out the warranty card. |
Author: | Mike OMelia [ Sat Oct 25, 2008 10:22 pm ] |
ToddStock wrote: low price of 2 for $165 each from one vendor, Well Todd, if you know of a 2fer deal, I am IN like Flynn! Mike ![]() ![]() |
Author: | Chris Paulick [ Sun Oct 26, 2008 7:46 am ] |
I think what Todd is saying that the supplier has 2 left and that's it as in all gone. |
Author: | Hesh [ Sun Oct 26, 2008 9:48 am ] |
The 310s are fantastic laminate trimmers and although I don't know for sure I think that they have about the lowest center of gravity available. When free handing this low CG is IMHO a plus. The sticking collet is a minus but that is what a Stew-Mac fretting hammer can be deployed to deal with..... Sadly it's moot since the 310's will be history unless you already have some. |
Author: | Chris Paulick [ Sun Oct 26, 2008 9:55 am ] |
What problem with the sticking collet are you talking about? I know that you usually have to give the tightening nut a tap with the wrench to loosen it most of the time. But that's the same on the 7310 and my larger PC routers too. I don't see it as a big deal though. It even states to do that in the 7310 's instructions, don't know about the 310 as I haven't read those instructions . ![]() The one thing that I don't like about the 310 is that although the CG is low which is nice it also makes it a bit harder to see the bit cutting causing me to have to bend over more to view it. I'm probably going to put a plexi base on it and cut the back solid section out of the mount to let more light in. Or just make a plunge base for it on a Wells/ Karol base. |
Author: | Hesh [ Sun Oct 26, 2008 10:33 am ] |
Chris my friend - that's it, having to tonk the nut but I don't see this as a problem either when balanced against the very fine reputation and performance of the 310. As for instructions - what are instructions....? ![]() ![]() People bring me up at times on the OLF and I am still very much annoying...... ![]() ![]() |
Author: | Rod True [ Sun Oct 26, 2008 3:30 pm ] |
Ya you are ![]() Back to the Bosch Colt. So has anyone seen this from Amazon.com Factory-Reconditioned Bosch PR20EVSK-RT Colt Palm Grip 5.7 Amp 1 Horsepower Fixed Base Variable Speed Router with Edge Guide for $69.95. My 1617 is from CPO recon division and when I got it, it was like brand new, not a scratch on it or the case and it works perfectly. I'd be jumping on that right there If the $ wasn't so bad up here. |
