Turnbuckle spreaders
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=19139
Author:  DanielC [ Thu Oct 09, 2008 9:26 pm ]
Post subject:  Turnbuckle spreaders
Not sure what you would call them, but where is the best place to buy the turnbuckle spreaders that you use to hold the rim tightly in the mold? thanks
Author:  Eric Mathre [ Thu Oct 09, 2008 9:31 pm ]
Post subject:  Re: Turnbuckle spreaders
Daniel,
I'm not sure where you live. I found a wide selection at my local
(regional) "Orchard Supply Hardware" here in California. I'd expect that
any large hardware/building supply place would stock them.
Look in the section where fence-building hardware is shelved, as I believe
their intended application is to provide diagonal tension in fence gates.
Eric
Author:  Martin Turner [ Fri Oct 10, 2008 3:19 am ]
Marine suppliers are a good source down here in Australia.
Author:  Allen McFarlen [ Fri Oct 10, 2008 4:50 am ]
Got mine in a dedicated bolt and fastener shop. They've got them in all flavors. Cheapest by far where the galvanized ones used for farmer's fencing. $1 each.
Author:  Ennis Guitars [ Sun Oct 12, 2008 7:30 pm ]
Lowes and Tractor Supply
Red
Author:  Mark Groza [ Sun Oct 12, 2008 7:39 pm ]
I wish they were a $1.00 here.I just use threaded rod with a wingnut reversed and a washer.
Author:  Peter J [ Sun Oct 12, 2008 7:47 pm ]
Check your local ACE hardware. They usually have a good assortment and the prices are reasonable.
YMMV
Author:  Mark Groza [ Sun Oct 12, 2008 8:01 pm ]
When they put a lowes store in nearby all the local ace hardware stores closed up.And they are expensive at lowes.So i use the threaded rod which i like alot.Thanks anyway,Mark
