Bender Crank Vendor? http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=19118 |
Author: | Steve Sollod [ Wed Oct 08, 2008 11:47 am ] |
Post subject: | Bender Crank Vendor? |
At one time there was a discussion about the cranking thing (clamp) that is mounted on a bender to bend sides and where to get one. I had saved a link to the vendor and now I can't find it and I can't remember who the vendor was... ![]() |
Author: | Michael Dale Payne [ Wed Oct 08, 2008 11:51 am ] |
Post subject: | Re: Bender Crank Vendor? |
i assume you speak opf a screw press. you want at least 9" and they can be found at almost any wood working shuppy store Attachment: 123-767.jpg
Author: | Steve Sollod [ Wed Oct 08, 2008 11:55 am ] |
Yes, a screw press, thats it! ![]() |
Author: | Michael Dale Payne [ Wed Oct 08, 2008 12:25 pm ] |
That is about a typical price. you can find them at Rockler, Lee Valley, Woodcraft, almost any woodworkers supply house. |
Author: | Ricardo [ Wed Oct 08, 2008 12:41 pm ] |
The 12" ones are a little harder to come by. I got mine from highlandhardware.com. You can also get them at Wetzler.com. |
Author: | Mike OMelia [ Wed Oct 08, 2008 1:41 pm ] |
mcmaster.com screw press |
Author: | Michael Dale Payne [ Wed Oct 08, 2008 1:46 pm ] |
Funny ting is most screw presses are sold in uneven number increments 7” 9” 11”. I guess this is because the screws are turned in a given number of threads per inch so the threaded portion of the screws tend to be machined in even number increments 8”, 10”, and 12”. Now you add the nut to the equation it will almost always eat up a 1” increment of the screw so if you have 12”of threaded screw length, less the nut length. that leaves 11” of adjustability in the press. |
Author: | JimWomack [ Wed Oct 08, 2008 2:33 pm ] |
Not to nitpick, but I believe they're called press screws. Screw presses are used to extract juices or oils from fruits, vegetables, nuts, seeds, etc. |
Author: | Michael Dale Payne [ Wed Oct 08, 2008 2:46 pm ] |
JimW wrote: Not to nitpick, but I believe they're called press screws. Screw presses are used to extract juices or oils from fruits, vegetables, nuts, seeds, etc. Jimmy that is beeing pretty much nitpicking ![]() ![]() ![]() |
Author: | gozierdt [ Wed Oct 08, 2008 3:00 pm ] |
Grizzly has their "Veneer Press Clamp" for $14.50. That may be the one you remember reading about... http://www.grizzlyindustrial.com/products/Veneer-Press-Clamp/H2597 |
Author: | Chris Paulick [ Wed Oct 08, 2008 3:46 pm ] |
Woodworkers Supply and Seven Corners Hardware carries 12" Jorgensen press screws but they're about $25 from 7 corners and $31 from Woodworkers. |
Author: | jsimpson [ Thu Oct 09, 2008 12:29 am ] |
I just saw an actual screw press in the latest Grizzley catalog...sorry, left it at work! It's not the veneer press mentioned above... I got some nice 9" ones from Rockler as well. |
Author: | Rick Cowan [ Thu Oct 09, 2008 7:52 pm ] |
Hi Steve, I bought my press screws (12") from Wetzler http://www.wetzler.com/press.shtml. The price was quite reasonable and delivery was prompt. Rick |
Author: | ChuckH [ Thu Oct 09, 2008 10:18 pm ] |
Thanks for the tip Rick, I just ordered one |
