Drop Fill or Re-finish?
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=18980
Author:  ChuckG [ Mon Sep 29, 2008 12:10 pm ]
Post subject:  Drop Fill or Re-finish?
I didn't fill the tiny gap between the side purfling and the side (lacewood) before finishing and now there is a visible line in many places where the nitro lacquer has sunken into the gap. Would drop filling be enough for this or should I sand the sides back down to bare wood, fill, and refinish?
Thanks in advance for any suggestions.
Chuck
Author:  Mike Collins [ Mon Sep 29, 2008 2:36 pm ]
Post subject:  Re: Drop Fill or Re-finish?
Chuck;
Do you mean a gap as in NOT glued?
Or a low spot in the finish?
Author:  ChuckG [ Mon Sep 29, 2008 3:38 pm ]
Mike,
Just a low spot in the finish. The binding and side purfling are well glued. I'd say the the deepest spots are maybe .005" or a little deeper. I use the CA method for gluing the bindings and usually any places that don't get filled completely are filled with epoxy when I fill the pores on the sides and back. This is my first experience with lacewood and it didn't seem to need filling, so I didn't. I guess I'll either need to be more careful with the CA when gluing, or make sure to do a fill with epoxy on the sides. The top and back came out great with no such issues.
Chuck
Author:  Howard Klepper [ Mon Sep 29, 2008 7:08 pm ]
Scuff sand, fill with epoxy, scrape and sand off ALL excess epoxy, spray a couple more topcoats.
Author:  ChuckG [ Mon Sep 29, 2008 8:09 pm ]
Thanks for the replies, guys. I appreciate the help.
Chuck
