It is currently Sat Aug 02, 2025 9:48 pm
PostPosted: Fri Sep 26, 2008 2:56 pm
First name: Ron
Last Name: Y
I've searched high and low, but this size chisel doesn't seems to be available. Does anyone know who has them? I want to use It for excavating the saddle slot in a bridge. Thanks for any leads.
Ron M.
PostPosted: Fri Sep 26, 2008 3:03 pm
how about grinding one down?
3mm is at least readily available
Frank
PostPosted: Fri Sep 26, 2008 3:26 pm
That's just over 2mm. 2mm chisels are available. I know LMI has them, but so does Highland Woodworking, and some others.
Hirsh 2mm Bevel Edge Chisel
PostPosted: Fri Sep 26, 2008 3:41 pm
PostPosted: Fri Sep 26, 2008 3:55 pm
First name: Ron
Last Name: Y
Hi Frank,
I can't grind a 2mm chisel because I don't have a grinder (or the skill), but thanks just the same.
I've seen the 2mm chisels all over the place. I guess i could make the saddle 1/8" since the 2mm size chisel is more readily available. Thanks Waddy.
Ron M.
PostPosted: Fri Sep 26, 2008 3:56 pm
Meaning that they are probably closer to 3/32 than 2mm?
PostPosted: Fri Sep 26, 2008 4:02 pm
1/8" - 3,175mm
3/32" - 2,38125mm
Frank
First name: Ron
Last Name: Y
Hi Waddy,
I'll go to toolsforworkingwood next week in Brooklyn, and check out some 2mm chisels.
Ron M.
PostPosted: Fri Sep 26, 2008 4:56 pm
First name: Ron
Last Name: Y
Thanks frank.
PostPosted: Fri Sep 26, 2008 7:44 pm
Ron, If you can "excavating the saddle slot in a bridge" you can take 1/32" off of a chisel.
All you need is a belt sander and some water. Get one of those cheap Marples blue handle 1/8" chisels (they are not bad chisels by the way ) and grind off the 1/32".
If you really can't grind one and can't find one let me know. I have some laying around that might be that size and if not I can grind them to that size. You might have to put a handle on it though.
Link
PostPosted: Fri Sep 26, 2008 9:02 pm
First name: Ron
Last Name: Y
Link
Thanks Lvc for the offer and the tips. I do have a Belt sander and I could order a 1/8" Marples, and I have some water laughing6-hehe.
ToddStock wrote:
The Pfeil 2mm #1 sweep (flat) single bevel chisel is usually available from Woodcraft or other Pfeil venders and is a nice tool for saddle slots. Also - my saddles are about 3" long (you had asked me at one time).
Hi Todd,
Actually, i was asking about the depth of the saddle (3/32" 1/8") but thanks for telling the length as well. Also, I'll look into the The Pfeil 2mm chisel.
Ron M.
Users browsing this forum: bobgramann and 46 guests
