It is currently Thu Jul 31, 2025 5:53 am
 Post subject: Resetting HHG joint?
PostPosted: Sat Sep 13, 2008 12:53 pm
I have googled HHG info, and it states that you can reheat HHG for up to 2 months or more until it completely hardens.
I have a thicknessed back I re-glued up, and the top 1" is off, the plates didnt merge, -can I just iron out the 1" of joint and reset it? I would rather not take the thing apart.
 Post subject: Re: Resetting HHG joint?
PostPosted: Sat Sep 13, 2008 9:57 pm
The joint won't be as close as if you were to separate the two plates and re-do the entire glue up. Because the plate is already thickness'd you'll have to clamp them along the seam to make sure that they are flush once the glue has set.
Users browsing this forum: doncaparker and 9 guests
