Nitro over shellac??
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=18095
Author:  Rvsgtr [ Wed Jul 23, 2008 6:58 pm ]
Post subject:  Nitro over shellac??
Anybody ever tried/had experience with nitro over a shellac sealer?
I'm finishing up a quilted honduran mahogany/carpathian guitar with curly maple bindings and don't want to stain. I like the color the shellac gives the mahogany (and a subtle darkening of the bindings) but the customer has requested nitro back/sides with french polished top. The vinyl sealer doesn't color the wood as much as the shellac and is the reason for my question.
thanks
SR
Author:  Martin Turner [ Wed Jul 23, 2008 7:26 pm ]
Post subject:  Re: Nitro over shellac??
Im not a nitro man but I believe shellac is a perfectly acceptable sealer under nitro.
Author:  Kent Chasson [ Wed Jul 23, 2008 7:34 pm ]
No probblems.
Author:  Hesh [ Wed Jul 23, 2008 9:07 pm ]
Piece of cake - works great.
Author:  Blanchard [ Thu Jul 24, 2008 8:19 am ]
Shellac works fine under nitro.
I use it to seal spruce tops and I spray vinyl sealer everywhere else. The shellac does a better job of blocking spruce pitch which can cause micro pitting in nitro lacquer.
Mark
Author:  Barry Daniels [ Thu Jul 24, 2008 1:14 pm ]
Mark
I have always wondered what caused that. I'll be sure to use a shellac sealer on spruce in the future. Thanks Mark.
Author:  Mike Collins [ Thu Jul 24, 2008 1:42 pm ]
the "lac" in lacquer is Shellac !
That was used as the base ingredient at first!
may still be!
But they add plastizers& all kind of stuff to make it more durable and less suseptible to sweat & heat!
it works great under Nitro!!!!!!!!!!! bliss
Please excuse my spellings!!!
mike
Author:  Rvsgtr [ Fri Jul 25, 2008 11:27 am ]
thanks everybody. I thought it would work but wanted to be sure. I actually normally fire a light coat around the edges of the top prior to binding purfling to save small fibers from being lost with the taping process. Then I usually sand it off prior to finishing. Now I won't have to be quite so judicious when final sanding the top.
thanks again.
SR
Author:  Chris Paulick [ Fri Jul 25, 2008 3:46 pm ]
The one thing to watch is that you don't put the shellac on too thick as that can cause checking if exposed to cold too rapidly. Other then that I thought that shellac was pretty much the norm. The old spit coat. Isn't putting on orange shellac the way to get the vintage/ aged color on a spruce top?
