After sanding...
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=17730
Author:  SkyHigh [ Tue Jun 24, 2008 5:32 pm ]
Post subject:  After sanding...
I'm in the middle of adding tapes and braces on the sides and wanted to ask questions about how to clean up before joining in general.
For example, when you glue side braces or tape, do you just run the sides with dry paper towel before glueing the braces on? or use some sort of solvent like distlled water to get any wood dust off before applying the braces and glue?
Same question goes for when joining other parts such as joining top to the sides, do you just wipe with dry towel before joining with glue...or?
And if you use some kind of solvent, how long do you let it dry before joining?
thanks, David
Author:  Michael Dale Payne [ Tue Jun 24, 2008 7:37 pm ]
Post subject:  Re: After sanding...
Hum, by the time I start gluing anything on the rim I have cleaned up any heat marks with a cabinet scraper and wiped down with naphtha to remove any surface oils or anything that my hands may have left behind.
Author:  Hesh [ Tue Jun 24, 2008 7:38 pm ]
I just vacuum with my Festool and then pry the rim off the nozzle since the Festool is so powerful......
Author:  Michael Dale Payne [ Tue Jun 24, 2008 7:57 pm ]
so you are saying that festools suck? :!:
Author:  Hesh [ Tue Jun 24, 2008 7:58 pm ]
Yeah.... :D I married mine last fall...... :D
Author:  Michael Dale Payne [ Tue Jun 24, 2008 8:16 pm ]
I know I started it but... No coment oops_sign
Author:  AndrewGribble [ Tue Jun 24, 2008 9:47 pm ]
Ask a reasonable question and ya get tweedle dee and...
...wonder why 'the pros' don't stop by as often. Hmmm...
David, if you mean getting rid of the dust on the inside of your sides I think a dry paper towel or clean t-shirt would suffice. A good blast with a compressor would probably be even better. Especially after bowl sanding before gluing your top to the sides.
In this case I don't think you'd need any solvent.
Author:  Lillian F-W [ Tue Jun 24, 2008 10:39 pm ]
Gawd, I don't know if they still make them any more, but I use my old drafting brush. I guess a soft bristled paint brush would work just as well.
Author:  Michael Dale Payne [ Wed Jun 25, 2008 8:46 am ]
First off; there are several quite renown pros here day in and day out. But apparently you don’t think them to be. This forum has always had a bit light heartedness comradeship to it that made it different than the other stuffy and click-ish forums we all familiar with.
Second; exactly what in my answer did I say that was twiddle de and twiddle dumb. If you refer to my quick joke with Hesh, then man you are stuffy
I freely share my experience here every day and do all I can to help my fellow builders and luthiers asking nothing in return and have done so for years at this forum.
Now you impugn me for a quick jab of humor and do so publicly instead of a pm to tell me you found my humor out of place. I have not and would not do such to you.
I am sorry you found our humor aggravating. But I am afraid I will always throw in an occasional quip of humor. I always have, and always will. At least till it is against the rules here and I am kicked off the forum. Till then I guess you just have to find my playfulness aggravating.
Chill
Yep they still make them
Author:  WaddyThomson [ Wed Jun 25, 2008 10:31 am ]
Come on, Michael, what's a little impugnity among friends? beehive wow7-eyes :D
I agree with you! Jab away. [:Y:]
Author:  SniderMike [ Wed Jun 25, 2008 11:56 am ]
Hesh, I believe you're a latent appliance fetishist. You need to pay a lot of money to L. Ron Hoover. He can help you.
As for the actual question, give it a good blow with the compressed air.
Author:  Mike Collins [ Wed Jun 25, 2008 1:11 pm ]
I use synthetic steel wool !(on the sides)
It leaves a nice sheen and no oils!
I polish my braces with it also!!!!
Then i still wipe with a cloth or blow out with compressed air!
Author:  Brock Poling [ Wed Jun 25, 2008 1:18 pm ]
I clean the insides spotless before I put the plates on. I steel wool the sides and carefully sand the back to make sure there are no marks on it before I install it. Naptha to remove any ghosts of pencil marks (you know ... the ones the eraser doesn't fully remove)
I blow it out with compressed air, then I run a magnet over it to pick up any misc filings from the steel wool.
I am a bit obsessive about it, but I really like the box to look as clean on the inside as it is on the outside. A guitar can live a long life and I think it deserves to go into the world with its best foot forward.
Author:  Barry Daniels [ Wed Jun 25, 2008 1:31 pm ]
Brock,
Don't you worry about the oils in the steel wool getting on the bare wood? I hate to use steel wool due the steel shavings left everywhere.
Author:  Brock Poling [ Wed Jun 25, 2008 2:59 pm ]
BarryDaniels wrote:
Brock,
I don't usually worry about the oils in Steel Wool. So far no problems (now watch lightening strike me. ;) ) and on the insides I have stopped putting any finsish in there.
With respect to the shavings I just use a rare earth magnet with a paper towel over it (to make the shavings easy to remove) and within a pass or two it is spic and span clean.
Author:  Don Williams [ Wed Jun 25, 2008 3:12 pm ]
There are steel wools out there that are oil-less IIRC. Isn't Liberon one of them? I could be wrong...but I've used it enough to not be afraid of the results from using it.
Brock....I totally expected that from you...
:D
Author:  Brock Poling [ Wed Jun 25, 2008 4:02 pm ]
:D
And you mean that in a GOOD way, right? 8-)
