Rear Venner (pics) http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=17620 |
Author: | sdsollod [ Mon Jun 16, 2008 12:04 pm ] |
Post subject: | Rear Venner (pics) |
Here is my 1st attempt at a rear veneer on a headstock. ![]() In hand-sanding the edges smooth it looks like I removed enough of the mohagany such that the sanded area is lighter in color than the rest of the neck. I have done some sanding on the rest of the neck but the overall color is not as light. I don't want to sand off too much... Also, notice the there is a darker area near the edge of the lacewood that doesn't seem to want to lighten up... any thoughts, comments, or suggestions? |
Author: | GregG [ Mon Jun 16, 2008 12:47 pm ] |
Post subject: | Re: Rear Venner (pics) |
I think if you sand the rest of the area into the lighter area WITH the grain it will blend in just fine.....try it then wipe it down with something and I bet it will look great. GG |
Author: | Mike Collins [ Mon Jun 16, 2008 12:48 pm ] |
Steve; the darkness in the neck is probably from the glue getting into the wood. You can sand this out without removing to much wood- or it's just aged(oxidized)wood that sanding will take care of also! I'm talking .005 " of wood-not to worry about that!! The 2 gaps you see can be filled with glue & dust -or carefully removed by sanding also! ![]() lacewood -neat combo of woodtones there(color) Go for it! ![]() Mike |
