Plugging or masking tuner holes prior to spraying a neck
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=17326
Author:  Mike Mahar [ Fri May 23, 2008 3:47 pm ]
Post subject:  Plugging or masking tuner holes prior to spraying a neck
In the past, I've just left the holes open and then "redrilled" them to clean out any finish that dripped in. This redrilling operation is a hassle and I'd like to mask off the holes in some way. Does anybody do this? I suppose that I could drill the holes after finishing but it's too late for my current instrument. Any suggestions?
Author:  David Collins [ Fri May 23, 2008 6:55 pm ]
Post subject:  Re: Plugging or masking tuner holes prior to spraying a neck
I've never known anyone to do this - seems like plugging would be a hole lot more hassle than simply reaming them out after finishing. The key word though is ream - not drill. If you decide to pre-drill holes before finishing, it shouldn't take more than a few seconds with a reamer to clean them out.
And yes, pun/typo intended.
Author:  Anthony Z [ Fri May 23, 2008 7:02 pm ]
Mike a couple options that have worked for me:
1) drill the peg hole 1/64" larger than 3/8" (i.e. 25/64"); or
2) plug the peg hole with disposable foam ear plugs; or
3) tightly pack the peg hole with paper towel.
Author:  Michael Dale Payne [ Fri May 23, 2008 7:50 pm ]
Yep form-able foam ear plugs or the swimmers gel ones are even better but much much more expensive ( 3 dollars a hole but reusable with waterborne. not so reusable with nitro)
Author:  Greg [ Fri May 23, 2008 8:32 pm ]
I just mark the tuner sites with a drilling of 1/16"" then after finishing I drill them with 3/8" or 10mm brad bit.
Author:  Dave Stewart [ Sat May 24, 2008 8:01 am ]
Ditto on foam earplugs (easily removable, no "fibers" etc.), then ream.
