It is currently Sun Jul 27, 2025 2:25 pm
 Post subject: hardwood top question
PostPosted: Tue May 20, 2008 8:43 am
First name: Martin
Last Name: Edwards
Hi gang, I have a guy asking me about making him a flat-top mando with a cherry top.
Now I KNOW that tops should be softwood.
but then I know that Ukes often have Koa top back & sides and there are all those all hog martin dreads........
so......
I assume that I'll have to sand it thinner than a spruce top, but other than that, what should I look out for/ beware of/expect?
and yes the thought that he's thinking of a cherry burst has crossed my mind....... :shock:
PostPosted: Tue May 20, 2008 8:48 am
It's all about stiffness/mass ratio with tops. You want a stiff wood that's good and light.
Reducing the thickness of most woods to a point where they're light enough to be driven by the strings results in them being too flimsy to cope with string tension. Though I've not worked much with cherry, I would presume that this is the problem you'd run in to, as it's the reason we don't use just any wood for our tops. I'm sure someone with more hands-on will be along shortly to advise.
PostPosted: Tue May 20, 2008 10:01 am
Martin,
I mean this in a nice way, why not try it and see? It's a lovely wood to be sure, and with your build speed, it won't be too drastic if it sounds bad. I would think they'd be an emphasis on trebles, though, with a slight reduction of volume and projection, being a stiffer wood than the common softwoods used.
There are a few maple top mandolins out there...
PostPosted: Tue May 20, 2008 10:03 am
I have built many Koa topped OMs and SJs and a few Maple topped. Most of my Koa tops were thicknessed pre-bracing to .100-.105 braced and tuned. most thinned on the perimeter of the lower bout after bracing to .090-.095
PostPosted: Tue May 20, 2008 4:37 pm
First name: Martin
Last Name: Edwards
LOL it's funny, you guys say "why not?"
over on mando cafe they're much more (but not totally) against it!!
PostPosted: Tue May 20, 2008 6:00 pm
I'm all for it, mainly to get a report back on how it worked - at someone's expense other than my own! [:Y:]
I've always loved mahogany flat tops, though their rarity in use for arched tops has kept me from developing a strong opinion there. I've been wanting to try cherry at some point for a flat top, but I'd love to hear your experience if you go first.
PostPosted: Tue May 20, 2008 6:40 pm
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
Michael,I was wondering what a Top Thickness for Koa would be on a Uke? Also as David has said,a hog top really appeals to me.I`d definately like to try that someday.
James
James W Bolan
Nashville Tennessee
PostPosted: Wed May 21, 2008 10:35 pm
James, on a uke I'd shoot for .065 to .070 on top. My all koa ukes don't seem as loud as the spruce top ones.
A higher purpose for wood.
Rich Smith
Issaquah, WA
PostPosted: Thu May 22, 2008 7:53 am
Only say no to stuff if it kills ya.
Cherry isn't commonly used in guitar/mando building, so anyone building with the stuff can report thier experiences for the benefit of humankind and the OLF archives. :D
I would go for it if I could build a little faster..eight-ten months is a long time to waste if it didn't work.....
PostPosted: Thu May 22, 2008 8:22 am
When you thickness to those dimensions to the tops feel as flexible as your normal spruce ones?
Do you have any information on comparison weights? My thoughts are the loss in volume will be due to a higher mass soundboard.
PostPosted: Thu May 22, 2008 11:17 am
First name: stan
Last Name: thomison
City: branson
State: mo
Zip/Postal Code: 65616
Country: united states
I am with others and say go for it. It may and probably will turn out very well. I am sure same questions arose when folks first did the mahogany tops and I personally like that look very much and have one in the planning stages as well as an all koa. The material means a lot, but the build will probably mean if it works or not.
PostPosted: Sat May 24, 2008 12:24 am
Thats a good point Jammy. I have never tried reducing a hardwood top to the same mass as a spruce top. What would it take? A .050 koa top to be equivalent to a .070 spruce top? I'm reluctant to go that thin with anything. I suppose one could lighten up on the bracing for the hardwood top. I'll try that next time to see if I can get more top movement with a hardwood top. Steve Grimes, a well known guitar builder prefers to put spruce tops on his guitars because they sound better. I expect his 30+ years have taught him that you can't achieve the same sound with a hardwood top as you can with spruce.
Rich Smith
Issaquah, WA
PostPosted: Sat May 24, 2008 1:04 am
I wonder if he's ever played an old mahogany top J-45. ;)
Music stores and collectors started hiding the old mahogany top Gibson Jumbos away in recent years. It turns out that too many people once they had heard them would go home and just burn their old D-18's and D-28's in the fire pit. It was just devastating the vintage preservation efforts, so collectors agreed that such power is best not made freely available to the public. It's true. You have to undergo psychological evaluation before, and a thorough debriefing after you're allowed to play one of these things. Just way too much power for some to handle.
PostPosted: Sat May 24, 2008 9:49 am
First name: stan
Last Name: thomison
City: branson
State: mo
Have 2 older 00015's. They are great sounding little guitars, for the cheapest ones Martin made until their laminated lines.
PostPosted: Sat May 24, 2008 1:34 pm
First name: Martin
Last Name: Edwards
current status is he's thinking about it.
I DO have a pile of cherry though........
Maybe I will, just to see.......
maybe a bolt on neck so I can salvage it more easily if it turms out awful!! duh
PostPosted: Sat May 24, 2008 1:51 pm
Has anyone ever tried/heard the Santa Cruz H13s that are all sycamore (t,b,s,n)? From a visual standpoint this has to be about the loudest 'looking' guitar I've ever seen. I just wonder how the sycamore tops sound.
PostPosted: Sat May 24, 2008 5:41 pm
Sycamore? Interesting.
PostPosted: Sun May 25, 2008 4:28 am
:shock: I don't know if I should believe that or not!
laughing6-hehe
I've always loved oak! I've entertained the thought of oak tops for sometime. I'm suspicious that many of the naysayers are just more concerned with the unknown factors of using a wood not common to tops. Or sides for that matter.
I don't think Ive ever even seen quartersawn oak though.
PostPosted: Sun May 25, 2008 4:30 am
I take that back! The Zootman has some!
PostPosted: Sun May 25, 2008 10:15 am
I have built with a lot of cherry, I love it. I have so far avoided the temptation to make a cherry topped guitar but I've thought much about it and have a piece set aside.
Bruce Crepps told me that in selecting a piece of koa for a top, you need to pay very close attention to all the usual grain factors. Runout in a top like this is very important because it is going to be thinner than usual so get a piece with as little of it as you can.
I have played the mahogany topped guitars talked about and they sure can do a great job, and I bet that a cherry guitar done right would, too.
JJ, I have a few oak parlor guitars- they have spruce tops, but back then oak was used all the time.
Mark Swanson
Swanson Guitars
Users browsing this forum: Bing [Bot], Chris Pile, Michaeldc and 20 guests
