how bout them necks?
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=16851
Author:  Frank Aarre [ Mon Apr 14, 2008 4:59 pm ]
Post subject:  how bout them necks?
I just remembered today that my brother had a cherry(Prunus avium) tree that we cut down a year ago, at that time i had planned on using to build some sort furniture, so we sealed the ends and forgot about until today...
I hurried down to my brother's to cut it into suitable pieces ,he was about to cut it into firewood eek . Well now i have split the logs into quarters and left them to dry. I did take one of the billets and hewed out a rough shape with my carving axe.
i was now wondering would this be a suitable wood for guitarnecks, or have i just ruined a nice cherry tree?even if it useless as guitarnecks, would you mind looking at how i hewed out the shape,is this the correct orientation of the growth rings?
Author:  Parser [ Mon Apr 14, 2008 5:24 pm ]
Post subject:  Re: how bout them necks?
Ideally you would have quartered it the other way, with the heel pointing towards the center of the tree...cherry is pretty stable wood though...probably OK>
Author:  Frank Aarre [ Mon Apr 14, 2008 5:26 pm ]
prunus cerasus would be the correct term
In my simple mind with the rings perpendicular to the fretboard would be the strongest way to, is this not so?
Author:  Parser [ Mon Apr 14, 2008 5:53 pm ]
that's more typical...but it seemed like since this piece is from so close to the center it might be otherwise?
Author:  fryovanni [ Mon Apr 14, 2008 7:51 pm ]
Cherry is good stuff.
Author:  Colin S [ Tue Apr 15, 2008 2:29 am ]
No, Prunus avium, is correct, this is the European 'Bird Cherry' and is native to northern Europe. Prunus cerasus is the North American relative.
Cherry is my favourite neck wood for steel string guitars, I also use it fro lute necks. I prefer to use a stacked heel and scarf head, but see no reason not to make a one piece if you can find some suitable wood. I also use it for the neck block when used as a neck. The wood can display some interesting pink and green figure.
Here's a P. avium neck.
Author:  Tom Morici [ Tue Apr 15, 2008 2:46 am ]
Frank,
I feel you have the grain the correct way, i would expect
your blank to twist as it dries. It looks like it came from a small
diameter tree. It may work but I would let it get good and dry
before you try and true it up.
Author:  Larry Davis [ Tue Apr 15, 2008 5:11 am ]
It does appear to be a very small diameter tree and there is a good deal of juvenile wood included in that rought neck blank. Juvenile wood is unstable and should always be discarded.
European cherry is Prunus avium, BUT it is also Cerasus avium a name assigned by Moench.
American cherry is Prunus serotina according to "World Woods in Color".
Author:  Frank Aarre [ Tue Apr 15, 2008 9:37 am ]
probably splitting hairs, but we have both the sweet and sour type of cherry here, and this is indeed the sour kind, and from what i can tell, googling this, it is prunus cerasus, with the sweet kind being prunus avium(i might well have been fooled by the internet though).
i had not inteneded this blank for any use, i've got a big pile stacked up for drying, just thought i'd rough something out to se if i had it right.
Author:  Frank Aarre [ Tue Apr 15, 2008 12:54 pm ]
well okay maybe not the biggest pile, but a pile nonetheless.
There were two trunks growing up from the root, the smallest being 10" diameter, the biggest 15-16" in diameter.
