Rosette & top bracing pictures http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=16653 |
Author: | crich [ Sun Mar 30, 2008 7:43 pm ] |
Post subject: | Rosette & top bracing pictures |
This is my version of a small jumbo, 16" lower bout. This is also a new design for me on a rosette. I'm hoping it's not too boring. ![]() ![]() |
Author: | Hesh [ Sun Mar 30, 2008 7:57 pm ] |
Post subject: | Re: Rosette & top bracing pictures |
Clinton buddy I like the rosette - nice job ![]() ![]() ![]() ![]() ![]() The bracing looks heavy to me and 11/16th at the X intersection pre-cap is higher then I would go. I typically will brace an OM with 1/4" wide X-bracing that is 1/2" high, pre-cap, at the intersection if this gives you any ideas. And on my guitars nothing else is as high as the X-intersection. IMHO the easiest way to learn to tap tune your tops is initially to shoot for an abundance of ring with good sustain and not a particular note. I will always remove mass from the sides of a brace forming a pretty sharp triangular profile. Then, once shaped, I tap the top holding it between the first finger and thumb just below the transverse brace on one side. If I can tap down the X legs following the X leg and it rings well I repeat the process with another brace. If it does not ring well and I already have a triangular profile I reduce the height of the brace in the dead location. For scalloped braces where the scallops are you are not shooting for the triangular profile of course. I tap and listen, shape, reduce height, etc. for all braces below the transverse brace. You can also hold the top balancing it with a thumb on the transverse brace in the middle and also balance it at the top of the sound hole. A problem area is where either the tone bars or finger braces intersect the X. If it is dead at these intersections with a chisel reduce the height of the finger brace or tone bars where it butts into the X until it rings better. |
Author: | WaddyThomson [ Sun Mar 30, 2008 9:07 pm ] |
I too, like the rosette. Looks like your are off to a great start. Keep the pictures coming. |
Author: | Peter Pii [ Mon Mar 31, 2008 10:42 am ] |
I'm certainly no expert here but I have learned from the great advice of this forum that the transverse brace and the x braces should intersect the linings. I'm not sure from your pics if yours will do that. I'm also thinking that you could shave a bit more from the sides, making them a little more triangular. Peter |
