It is currently Wed Sep 17, 2025 5:49 am
PostPosted: Tue Mar 25, 2008 2:46 pm
Does anybody know the formula to calculate how changes in scale length affect string tension assuming string gauge stays the same? For example, lets say I have a 650mm and 660mm guitar, both strung with the same gauge strings, about how much more tension does the longer scale guitar have?
Thanks!
PostPosted: Tue Mar 25, 2008 3:16 pm
This site has the calculator http://www.greenmanhumming.com/html/Str ... e%20applet
The inputs can be found from D'Addario's site http://www.daddario.com/Resources/JDCDA ... _chart.pdf
I have a spreadsheet on my other computer than kind of automates the calculations. If you want it PM me with your email address and I'll send it this evening.
PostPosted: Tue Mar 25, 2008 3:19 pm
John,
If you mean steel strings then this is the calculator I use.
If the guitars with scale lengths you quote were in EADGBE tuning with 12-53 strings then the 660mm scale length one would have a total string tension of 169.68lb and the 650mm scale length one 164.58lb.
Users browsing this forum: modkev and 16 guests
