Tail Block question http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=16481 |
Author: | Chris aka Sniggly [ Wed Mar 19, 2008 5:41 pm ] |
Post subject: | Tail Block question |
What should the orientation of the tail block be.....end grain facing the top and back of the guitar or end grain standing up and not contacting the sides? |
Author: | sharp_custom [ Wed Mar 19, 2008 5:48 pm ] |
Post subject: | Re: Tail Block question |
Tail block grain should run parallel to the grain of the sides. |
Author: | Chris aka Sniggly [ Wed Mar 19, 2008 5:50 pm ] |
got it.......thanks.......... ![]() |
Author: | Kent Chasson [ Wed Mar 19, 2008 7:48 pm ] |
With the side grain and end block grain all lined up, it helps to inset a cross grain piece to avoid a split should the guitar get dropped on the strap pin. |
Author: | Arnt Rian [ Wed Mar 19, 2008 8:06 pm ] |
I laminate mine from two pieces of mahogany with the grain going in oposite directions for the same effect. Others simply use plywood; why not? |
Author: | Terry Stowell [ Wed Mar 19, 2008 8:11 pm ] |
Also, consider using plywood. Won't crack. |
Author: | Chris aka Sniggly [ Wed Mar 19, 2008 8:35 pm ] |
well......I used a mahogany one. Once I got the profile on it....it was all good to go.... |
Author: | LuthierSupplier [ Wed Mar 19, 2008 9:38 pm ] |
ToddStock wrote: 1/2" Baltic Birch ply. That's what I use, light, stiff, and virtually indestructible! |
Author: | Chas Freeborn [ Thu Mar 20, 2008 12:33 am ] |
BB ply for me too. Make sure it's the good stuff, not the asian import. -C |
Author: | SkyHigh [ Thu Mar 20, 2008 12:44 am ] |
Where do you guys get your Baltic Birch ply? I don't recall Home Depot selling these...do I need head down to lumbar yard ? Thanks, David |
Author: | Rod True [ Thu Mar 20, 2008 2:20 am ] |
David you'll have to go to your local wood vendor, most retailers who sell an assortment of hardwoods will usually sell Baltic Birch plywood. I too use 1/2" BB for my tail blocks and am considering using two laminated 5/8" pieces for the head block. |
Author: | Mattia Valente [ Thu Mar 20, 2008 6:31 am ] |
'home made' plywood (well, usually about 3 to 5 mm thick plys) made of mahogany and spruce, or just mahogany. It's not like I don't have the scrap, looks nice and clean, and the lamination (I use polyurethane glue) works just fine. Cheaper than baltic birch ply, since I don't pay myself for the time... |
