It is currently Wed Jul 23, 2025 4:05 am
PostPosted: Mon Mar 17, 2008 5:37 pm
City: Jacksonville
Hey folks....check out this back set I got from LMI today. Sweeeeeeeeet. The sides have sap on them also...but no pic.
Mainly though I have a question about the mold. This is my second mold today. See how it's off the plan a little? Does that matter? I can make another....I just don't want to be the king of mold making....BTW...this is the Antes OM plan...
Thanks a bunch......Chris
PostPosted: Mon Mar 17, 2008 5:42 pm
Not sure what others will think, but I wouldn't bother with the difference and go ahead and use this one.
Alain Moisan
(Now building just for fun!)
PostPosted: Mon Mar 17, 2008 5:44 pm
It's fine, go ahead and use it, without a second thought.
PostPosted: Mon Mar 17, 2008 5:53 pm
it is not off,
it is your version of the OM.
PostPosted: Mon Mar 17, 2008 6:08 pm
Paper plans are subject to print scale error, printer induced heat shrinkage and humidity changes. Also depending on the weave of the paper the amount of out of scale may or may not be the same in all axis or consistant across the whole page.
By the way your mold is fine
PostPosted: Mon Mar 17, 2008 6:09 pm
City: Jacksonville
That's interesting......my version....I like that..... bliss
PostPosted: Mon Mar 17, 2008 6:21 pm
Last Name: Abercrombie
Guitars are like boats in one respect:
As long as you make the same mistake on both sides, nobody will notice!
PostPosted: Mon Mar 17, 2008 6:52 pm
First name: kurt
Last Name: thomas
City: colden
State: ny
Zip/Postal Code: 14033
Just put the plans in the bathroom when you are taking a shower, keeping the mold in the other room of course, this should solve the problem. laughing6-hehe
_____________________________
Kurt Thomas
"There's a first time for everything even if you do it by mistake."
PostPosted: Mon Mar 17, 2008 8:54 pm
Just to play devil's advocate, or if you are some kind of deranged lunatic perfectionist, you could glue/laminate some thin veneer pieces to close up the discrepancy. My sides have yet to fit absolutely perfectly into my molds as I am still hand bending and a beginner. But the guitars still come out pretty good anyway imho. Don't worry...
PostPosted: Mon Mar 17, 2008 9:28 pm
Bondo has been suggested as a filler.
PostPosted: Mon Mar 17, 2008 10:19 pm
I use bleach for my mold problems. laughing6-hehe
Close enough as long as its symetrical. Party on. [:Y:]
PostPosted: Mon Mar 17, 2008 10:22 pm
..or how about, Thats not mold in the sap line ... we call it spalting. laughing6-hehe
Its late, I need some sleep. [uncle]
PostPosted: Tue Mar 18, 2008 9:36 am
Sniggly,
John at Blues creek has been producing my molds for me and they are as exact as the info I give him. Great work he does. That said about a year ago I lined the interior all my molds with .005" thick UHMW pressure sensitive film to avoid any chance of a accidental glue drop causing any issue.
I would tell you why but then I would be admitting that I have clay feet, and that aint happening laughing6-hehe
But anyway none of my clients have noticed that their guitars are .01" shorter than they are claimed to be laughing6-hehe
PostPosted: Tue Mar 18, 2008 10:20 am
I've used bondo to fill an mistake I made in a mold, When sanding with a spindle sander I noticed the wood of comes off faster than the bondo, it was ok, just had to keep this in mind when sanding it.
Stef
PostPosted: Tue Mar 18, 2008 10:24 pm
chris,
i agree with the others. use the mold.
and seeing as you're asking this kind of question, and using the antes plan, i'd strongly recommend hunting around in the archives for discussions that discuss the bracing on that plan. all the braces are in the right place, but boy are they ever heavy.
before i built my first guitar, using that plan, i was fortunate enough to have a professional look at the plan and scribble all the right rough dimensions onto it. he saved my bacon. had i built according to plan i would have ended up with a dud and my hobby would have ground to an immediate halt.
good luck as you start building.
phil
PostPosted: Tue Mar 18, 2008 10:30 pm
STEVE!!!! I used veneer to shim my molds................... I admit to being deranged but I am NOT a lunatic.....yet..... :D
All I would add is to over lay the two halves and remove or add material as needed to make both halves the same. I doubt if anyone's OM is exactly the same including the variances in the molds that martin probably uses too. But I would go for symmetry.
PostPosted: Tue Mar 18, 2008 11:45 pm
City: Jacksonville
Well......I'll tell ya what I did. I have a very large 'book' of tracing paper in my shop. I used it to copy furniture from photos in books and then scale out the trace.
I took a piece of that trace paper and laid it across one side of the mold....the side I thought was most correct....all the while aligning the edge of the trace paper with the center line of the mold. I used a charcoal artist's pencil to 'copy' the profile on that edge....flipped the paper over..pressed hard...and BOOOM...as I lifted the tracing paper....I found a perfect black line on the other side....I promptly fixed it on the spindle sander.
I AM THE MOLD MAKER.....SEE ME LAY DOWN THE MOLDS!!!!!!!!!!!!!!!!!!!!! :geek:
I always wanted to say that....heheheheheheh
By the way Heshter...I am going to use the 25 15 radii you mentioned.
PostPosted: Wed Mar 19, 2008 1:06 pm
City: Jacksonville
Look at my stuff.... bliss
PostPosted: Wed Mar 19, 2008 1:13 pm
John,
Your comment have been sigged. If you don't mind!!! :mrgreen:
