It is currently Fri Jul 18, 2025 5:39 am
Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
PostPosted: Thu Jun 27, 2024 8:06 am
Terence Kennedy wrote:
Copying a Martin bridge was what I did when I started and quite honestly the only major change I made later was aligning the pin holes parallel to the saddle slot and going with unslotted bridge pins.
One thing I like about the Martin design is the asymmetric radius that helps even out the amount of exposed saddle on the bass and treble side.
All great improvements on a solid base design. You know Terry I can't remember the last time the asymmetrical Martin bridge radius came up on the OLF. I'm betting that you just sent a whole lot of people to take a closer look at their Martins and that's a very good thing.
Bottom line as Terry points out there are a whole lot of things that can go into a great bridge design that we may not even notice or be aware of.
PostPosted: Thu Jun 27, 2024 8:23 am
Same thing plus I extended the belly about 0.1".
PostPosted: Sat Jun 29, 2024 5:21 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
Not sure if it is asymmetry in radius so much as a laterally offset center point for that bridge top radius. For through saddle designs, that forces a roughly 0.040" deeper slot depth at the treble side if one wishes an equal reveal of saddle into the bridge wings.
Gibson did something similar on their flat-topped bridges with some taper from bass to treble sides, while Taylor and others went with the easier-to-manufacture flat-top bridge and enough saddle setback to prevent saddle slot failure from the tipping loads.
- Beth Brower
Users browsing this forum: Colin North and 15 guests
