It is currently Sun Jul 20, 2025 12:09 am
PostPosted: Fri Sep 15, 2023 3:10 am
Routing a saddle slot on a new build.
Forgot to tighten the router body plunge base retaining clip for the cut. gaah
Fortunately the router body''s weight seems to have ensured a flat bottom, and ended up with the slot's width even but 0.3 mm (12 thou) wider than planned.
:oops:
These users thanked the author Colin North for the post (total 2): Kbore (Fri Sep 15, 2023 9:25 am) • Chris Pile (Fri Sep 15, 2023 8:16 am)
PostPosted: Fri Sep 15, 2023 3:52 am
Enter the saddle blank..
These users thanked the author meddlingfool for the post: Chris Pile (Fri Sep 15, 2023 8:16 am)
PostPosted: Fri Sep 15, 2023 8:17 am
Online
Yuppers.
Adapt your bridge saddle to fit. No one will notice and you'll look like a genius if they do.
These users thanked the author Chris Pile for the post: Kbore (Fri Sep 15, 2023 9:26 am)
PostPosted: Fri Sep 15, 2023 9:27 am
First name: Karl
Last Name: Borum
Zip/Postal Code: 63303
Colin North wrote:
Routing a saddle slot on a new build.....
Do you route your saddle on or off the top?
Measure Twice,
Karl Borum
PostPosted: Fri Sep 15, 2023 12:24 pm
Personally, this is why I create the bridge entirely off the guitar.
I’m glad for you that your saddle slot is a consistent width and that you’ll be able to get away with it.
For me it’s no challenge to get the saddle slot and pins in just the right spot.
But the risk of doing it after glue up is not worth the reward IMO. The reward only being that the saddle slot is in the right place, which can be achieved by other means. Whereas if you experience a bit breaking, the brushes on your router going out, or a power outage mid cut etc., you’re faced with either having to fill and reroute the slot or worse, having to remove a fresh laid bridge, both of which are time sucks. I build in a very risk averse method…
These users thanked the author meddlingfool for the post (total 2): J De Rocher (Sat Sep 16, 2023 3:08 pm) • rbuddy (Fri Sep 15, 2023 1:02 pm)
PostPosted: Fri Sep 15, 2023 12:56 pm
Bridge glued on the top.
PostPosted: Fri Sep 15, 2023 1:01 pm
Used to rout it off the top, just I prefer doing it this way and use a floating saddle to set intonation for the particular guitar's set-up (strings, action etc.
Each to his own.
