It is currently Fri Jul 25, 2025 2:53 am
PostPosted: Sun Aug 28, 2022 11:01 pm
I received an order of b/w/b purflings that are 0.250" tall instead of standard height. I can't exchange it, so I have to ask, what do people use it for? I have come up with 2 choices.....
1) make a jig and slice it along its length to a more manageable size
2) lay it beside the top binding, which will eliminate the shelf but result in a much wider binding channel.
Any ideas would be appreciated,
PostPosted: Mon Aug 29, 2022 6:17 am
First name: Colleen
Last Name: McTigue
City: St. Catharines
Maybe it would be for celli and basses? Seriously, I can’t imagine. Using it alongside the binding sounds like the easiest option.
These users thanked the author Colleen_M for the post: LaurieW (Mon Aug 29, 2022 4:57 pm)
PostPosted: Mon Aug 29, 2022 7:58 am
Last time I had some wide wood purfling I made a jig and sliced it. Jig was wood with a covered groove the width of the purfling and a razor blade stuck at about a 45 degree angle. Wasn't a precise cut as the cut wandered a bit with the wood grain but it worked ok. A more precisely sized groove would have helped there.
These users thanked the author SteveSmith for the post: LaurieW (Mon Aug 29, 2022 4:57 pm)
PostPosted: Mon Aug 29, 2022 8:43 am
As long as your linings are wide enough you can cut the purfling rebate to the same depth as the binding rebate and install the purfling and binding at the same time.
These users thanked the author Clay S. for the post: LaurieW (Mon Aug 29, 2022 4:56 pm)
PostPosted: Mon Aug 29, 2022 4:56 pm
Thanks for the input, I will see how it goes!
PostPosted: Tue Aug 30, 2022 8:43 am
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
My thoughts: Help is but a mailman away. Buy the right stuff, store the wrong stuff, and carry on. Do't try to make do/modify/work around the wrong stuff. I think there's plenty to do during the few days it takes for the mailman to bring salvation. For the small dollar cost of the right stuff, I think time is more valuable than money.
Peter Havriluk
These users thanked the author phavriluk for the post: LaurieW (Tue Aug 30, 2022 1:08 pm)
PostPosted: Tue Aug 30, 2022 3:24 pm
First name: Casey
Last Name: Cochran
City: Gainesville
State: GA
Zip/Postal Code: 30501
Full depth purflings eliminate the step that is occasionally visible with tortoise binding.
Good judgement comes from experience. Experience comes from poor judgement.
PostPosted: Tue Aug 30, 2022 8:13 pm
As long as you have linings that are wide enough to support full depth purflings I don't see a downside to them. You won't sand through them if you are heavy handed on the perimeter sanding (you'll sand through the top first! laughing6-hehe )
