It is currently Wed Jul 23, 2025 2:01 pm
PostPosted: Thu May 05, 2022 6:03 am
First name: CHARLES
Last Name: HENNET
State: PA
I see in piano and harp building it is common to dry the soundboard in a hot box before attaching the braces. You can also see Jonny Kinkead possibly doing something similar in the build series linked below:
https://www.youtube.com/watch?v=aAV9U3WzzP8
Dan's Acoustic Guitar Build Part 1/5 With Master Luthier Jonny Kinkead
Does anyone building here have an intentional heated drying session before gluing the braces?
Chuck
PostPosted: Thu May 05, 2022 6:22 am
Hard to find with no reference in your post to specific time /part - ?/5 no.
I bake my tops (and bracing) in a hot box (95-100 deg C 1.5 hrs) and leave them to re-acclimatize them before jointing the top and bracing it to pre-shrink and condition them (quite a common practice - taylor etc.), but would hesitate to heat the soundboard in a hot box before bracing because of the glue joint.
I've heard Martin used to keep their tops in a warm area (attic?) before bracing if that helps.
These users thanked the author Colin North for the post: davidson (Thu May 05, 2022 6:24 am)
PostPosted: Thu May 05, 2022 6:54 am
First name: CHARLES
Last Name: HENNET
State: PA
Thanks.
Kinkead video part 1 of 5 around 12:02.
PostPosted: Thu May 05, 2022 8:09 am
In a drying cabinet he says, looks like he's using a domestic a domestic air conditioner, maybe to feed dry air (which will be warm) into the drying cabinet.
PostPosted: Thu May 05, 2022 9:10 am
I have used an oven before but if you keep your wood in your controlled shop you should not have an issue with it imho.
PostPosted: Thu May 05, 2022 9:37 am
I bake all my tops just to get put them through the first cycle of shrinkage and let them acclimate before gluing on the braces. A world-class classical builder I know dries his tops to 3% and glues his braces with the tops still at 3%. When they acclimate to his shop humidity, they expand, forcing a dome.
PostPosted: Thu May 05, 2022 10:17 am
Pat, does he brace the top in a flat condition? Interesting.
PostPosted: Thu May 05, 2022 1:18 pm
Jim,
Couldn't tell you. If I get a chance, I'll ask him next time I see him.
PostPosted: Thu May 05, 2022 2:13 pm
Thanks!
PostPosted: Thu May 05, 2022 6:46 pm
First name: CHARLES
Last Name: HENNET
State: PA
Thanks all.
PostPosted: Fri May 06, 2022 5:24 am
Bracing in extremely low RH has been done by piano manufacturers, violin makers, mando makers and guitar makers. It's another approach to producing instruments that can withstand RH swings to a greater degree, hopefully. We think it's helpful but it's not anything new it's been done for a very long time and likely was done before we had machines to manipulate our environments by batching work and jobs for seasonal opportunities when the RH is right.
